Question about Kitchen Ranges
Range loosing pressure at burners - oven won't come to temp
Fuel supply is sufficient - regulator on tank is good. Initial ignition appears ok, but burners eventially die down. Oven will fire once or twice then shut down. It acts like there is a restriction - but none between tank and range. I don't have a parts manual,so don't know if range has an appliance regulator, or if it is a combination valve/reg. Range is Whirlpool, Model 465.
    President:
  • 2,110 Answers
If you are still under warranty, and have "lemon laws"... repaired three times in the warranty period for the same problem... they have to replace the stove. We all need to get Kitchenaid to start replacing these ranges over and over, maybe then they will address the issue. Clean, baby clean... you paid extra for a self clean oven, hold Kitchenaid accountable!
Posted on Feb 08, 2009
  • 679 Answers
Please follow the link for more information>>
http://home.howstuffworks.com/how-to-repair-an-oven2.htm
let me know for further assistance.
Thanks
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
Most burner troubles can be quickly solved by adjusting the air shutter mixer plate, which is located at the end of the burner tube near the knob controls. Turn a small screw on the plate, slide the plate open or closed, and tighten the setscrew.
If the flame is yellow, it's not receiving enough air. To allow more air in, open the plate slightly. If the flame is high or makes a roaring noise, it's getting too much air and you should close the plate slightly.
Posted on Jan 28, 2009
  • 495 Answers
For parts manual please visit:
http://kitchen.manualsonline.com/manuals/mfg/whirlpool/oven_1_2_3.html
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Fuel pump cycling long time bike won't fire,has good spark.
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
What to do When Your Motorcycle Won Start
1098 won start
Ducati 907 906 Paso Workshop Service Repair Manual 1988 1993 Searchable...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Mar 14, 2013 | Ducati Motorcycles
2007 FLHTC runs but won't stay running
Hi James, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Feb 14, 2013 | 2007 Harley Davidson FLHTCU Ultra Classic...
1995 Ducati 750 ss wont start
1. Fuel tank empty.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
1999 750SS engine turns over but won start Ducati ms The Ultimate Ducati...
Ducati won start Biker ie Forums
Free Ducati Motorcycle Service Manuals for download
Ducati Maintenance
Jan 10, 2013 | 2002 Ducati 750 SS
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
I have a Maytag 30 gas oven. When you set the temp., the oven fires up but the gas will turn on then off. Repeating this cycle over and over. It looks as though the gas supply is having a pressure or...
If it were the regulator you would have the same problem with the top burners. Is the oven burner coming on a little or to normal size? How long does the burner stay on each time?
Jan 16, 2010 | Maytag 30" Self-Cleaning Freestanding Gas...
I have a kenmore range the oven burner does not work but the broiler does. The igniter on the oven element appears to glow in preparation of lighting but propane does not come out of the element. Now when...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
sgf
Nov 16, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven gas will not flow with pilot lit
There are basically two types of ranges to deal with:
those with sealed top burners, which are pretty much the standard today, and the conventional, 'non-sealed' ones.
While they operate in much the same way, their conversion is usually different. There are still a few ranges that use adjustable sealed burner orifices, but most are 'fixed' and must be individually replaced to convert each burner from one fuel to another.
(An orifice is simply a small brass fitting with a specifically sized hole very accurately drilled through it, and, if adjustable, has a provision to change the size of this hole by turning closed a threaded portion).
Either way, basically what you're doing when going from natural gas to LP is changing to a smaller orifice to allow for the higher pressure supplied by the 'bottled' gas (The available energy in each ft of gas is different too, but for our purpose here that's not important). Natural gas supplies typically run around a pressure of 5.5 inches water column, while LP runs at twice that pressure, averaging around 11 inches.
The orifice through which the gas travels to the burner must be smaller to accommodate this difference.
Adjustable orifices are simply 'snugged' down, clockwise, with a 1/2 inch open-end wrench, to convert them. Nearly all oven burners use these too - more about that in a minute.
Fixed orifices are replaced, and the good news is: the LP parts are usually included with the new range. On some brands (GE being one), the unused set is attached to a storage point on the stove, and this is a great idea. This way, they can't get lost, and if you ever want to convert back, there they are!
The not-so-good news: these little top burner orifices very often require a metric wrench to remove & install. And some can't be changed without a very slender wrench or nut driver.
Aug 08, 2009 | Imperial Kitchen Ranges
Not enough gas to range?
you either have a gas pressure problem from your meter outside or a bad pressure regulator on the range. if you use a magnehelic guage (get from a plumming supply house) you should be getting about 11inches of water coloum, or you can call your gas company to check it out... Let me know how it goes.
Jan 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Top burners often wont light if oven is already lit
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Kitchen Ranges Logo
172 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
