Question about GPX D715 Clock Radio
Cant get time to stop flashing
Power went out, reset the time but it won't advance or stop flashing
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
How do I set the digital time in my Surface 31874 watch?
When you press the Mode button:
1st press: FRI, SAT, SUN arrows flash. This is chronograph mode. Use START/STOP for stopwatch and RESET for split/clear.
2nd press: MON arrow flashes. This is where you set the alarm. Use START/STOP to advance number, and RESET to switch between minute and hour.
3rd press: TUE arrow flashes. This is where you set digital time. Seconds (in analog time window) flash first. Use START/STOP to reset seconds or advance number, and RESET to switch between seconds, minutes, hour, date day, and date month. Press mode again to exit. Have fun!
Oct 19, 2012 | Watches
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Microwave won't set clock
It is most likely the keypad control board has been damaged, first! unplug the microwave oven for 5 minutes, if this works the micopressor will reset, if it fails the control board will need to be replaced, a costly venture.
Apr 14, 2012 | Danby DMW1153 Microwave Oven
HP F4140 Printer - all lights flashing, blinking E
This is a printer hardware error, you cant try below reset methods.
Power Drain:1. Unplug the printer power cord from wall and the printer, disconnect USB cable from printer.2. Press and hold the power "ON/OFF" button for 30 seconds and release it.3. Connected the power and check the printer.
Dec 08, 2011 | HP DeskJet 6988 Printer
Cannon mp170 orange light flashes twice then pauses then flashes twice and so on i cant get my printer to do anything
Try resetting the printer:
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
Nov 27, 2011 | Canon PIXMA MP170 All-In-One InkJet...
GPX D715 Clock Radio Logo
35 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
