Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit !DL 40 s dishwasher lights 1 and 2 flashing and water not draining/pumping away
  • 641 Answers
SOURCE: Water not pumping away
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. It could be as well a defective or a malfunction pump. Let me know if you will need for further assistance. Good luck!
Posted on Sep 16, 2007
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
Posted on Nov 18, 2007
SOURCE: Indesit IDL 40 Slimline flashing lights
I have the same problem as well. I have tried adding salt, but I still get the flashing lights.
Does anyone have a solution?
Posted on Mar 01, 2008
  • 4 Answers
SOURCE: Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Posted on Apr 24, 2008
SOURCE: Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Posted on Oct 06, 2009
Lights 1 and 2 flashing indesit IDL40
I used the solution above and my dishwasher now working!!! I would add, plenty of towels and a tray or three to catch the stinking water that comes out of the outfow when you tip it up. Yes 6 screws to remove the back, but on the Indesit IDL40 two additional longer screws in the centre are helpful to remove. Then just tuck the bit that was attached out of the way. My pump was cream and white - check out pumps online to see what they look like. Undo the one screw holding the pump in place and then you have to twist it to release three little pegs. I washed outs loads of small bits of grit. Then easy to put back together. Re-attach the drain pipe to your drain, electric plug at wall and water inflow pipe. (Check for leaks!) I am so happy! Took me two hours but I had to hunt for the info and find the hidden screwdrivers. Husband will be pleased I think.
Jan 11, 2014 | Indesit 18 in. D41 Slim-Line Free-standing...
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Indesit DI 620 which won't drain water
this appliance is a built in dishwasher and may have somthing jamming the pump,this can only be acessed from the bottom and may require the appliance being removed,also check that there is not a blockage at he sink.
Apr 19, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit D41 lights 1 & 2 flashing
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
Dec 21, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit dishwasher DV62
You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
47 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
