Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
Brother printer message ,unable to print 48 see trouble shooting and routine meintenance
  • 826 Answers
I think the encoder strip needs to be cleaned with a lint free cloth. If the encoder strip gets dirty, many different problems can occur.
If the machine still errors, the encoder strip needs to be replaced - Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly - Part Number LS6543001
If the machine still errors, replace the Printhead - Part Number LK3211001
If the machine still errors, replace the Main PCB assembly - Part Number LT0284011
Posted on Jan 24, 2013
Soulvisitor
  • 1113 Answers
SOURCE: will not print
You have a major error, probally head stuffed error 41, to find out your error press menu starte and up 4 times, this may show error if not then input 82 set, error will display.
Post back if need more info
S.
Posted on Jan 14, 2008
SOURCE: user's guide- trouble shooting and routine maintenance
printer will not print referring me to the trouble shooting and maintenance chapter in the manual which I can't find......I have a Brothers MFC-420cn CAN YOU HELP ME......
Posted on Feb 05, 2008
Mix-it-up
  • 832 Answers
SOURCE: UNABLE TO PRINT
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Posted on Feb 13, 2008
Mix-it-up
  • 832 Answers
SOURCE: error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Posted on Jun 23, 2008
  • 742 Answers
SOURCE: "Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET
b. 0 then press SET
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET
b. 7 then press SET
a. 8 then press SET
b. 3 then press SET
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET
b. 1 then press SET (To reset unit)
a. 9 then press SET
b. 9 then press SET (To exit Maintenance mode)
Posted on Jul 11, 2009
My brother 420cn said unable to print see manual trooble shooting and routine maintenance, but I don't have a manual.
Have you checked at the Brothers web site? I find that they have the product manuals easily available. I have had two Brothers printers. I always lose the manual.
Nov 29, 2011 | Brother MFC 420CN All-In-One InkJet...
UNABLE TO PRINT, CHECK ROUTINE MAINTENCE AND TROUBLESHOOTING I
Could be many problems. Did you get a error code number? If so, look for that in the manual or go to the brother website and check
Jun 16, 2010 | Brother MFC-9420CN All-In-One Laser...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
46 means the ink absorber box is full, it only costs around $10.00 to replace but you need to get into service mode to reset the counter. I'm not allowed to give out that info...
Sep 15, 2009 | Brother Multi-Function Center MFC-240C...
Print unable see trouble shooting and routine maintenance
sending fax is working alri.ght, only when I try to recieve fax it gives an error 30 on the display. At the same time it unable to clean. Please help me with this.
Jan 17, 2009 | Brother Multi-Function Center MFC-240C...
Error message on my mfc 420 mc
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Will not print
S.
Jan 14, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
219 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
