Question about Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer
How do I replace the pump in my front load washing machine
My front loader stopped spinning and draining right before we moved out of state. I had a repairman come and drain it since we didn't have time to wait for the part to get it fixed. He told me that I could easily replace the part myself, that there are only two screws to remove. But I want to make sure I do it correctly. Can you tell me how to do it please? Thank you!
  • k8thegreat
    k8thegreat Jan 26, 2013
    After reading through recommended posts in FixYa I began to have doubts that the problem with my washer was the pump, even after a "trained and experienced" repairman told me that was the issue. I read several other posts with the same symptoms as my machine and found out that it's actually a faulty door switch. I have ordered the part and hope to have it fixed soon. Thanks for the help!
  • Frigidaire Master
  • 17,129 Answers
Click for tips to replace the pump, PUMP
Posted on Jan 24, 2013
catriver
  • 878 Answers
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
holla, Im not showing a E20 code on the tech sheet. There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump...Catriver.
Posted on Aug 04, 2007
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
SOURCE: front load model LTF2940ES3 won't spin
I have the same washer and it will wash and drain but not spin. I replaced the door switch and the problem was solved.
Posted on Jun 16, 2009
MNfisherman
  • 11896 Answers
SOURCE: Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
Posted on Jul 09, 2009
Macmarkus
  • 2605 Answers
SOURCE: Frigidaire affinity front load. Starts
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **unplug the washer from the wall...safety first of course.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
P.S.
There is a slim chance of a faulty motor or motor control board, but that would not be where I would direct you to start...those are exceptions rather than the rule.
Thank you for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Dec 12, 2010
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
My ge front end loader washer won`t spin water or pump water out
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
It is not spinning now.
Depending on the make and model top loader or front loader, the most common issues are the lid switch or door lock safety interlock, or the pump filter is clogged and need cleaned. Let me know what machine you have and I can go from there.
Jan 27, 2011 | Washing Machines
Whirlpool front loader washer is not spinning
heatman101
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My top washer loader would not drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Nov 04, 2010 | Frigidaire ATF6000ES Front Load Washer
My samsung vrt front loader will not drain or spin and showing nd code
heatman101
Aug 28, 2010 | Samsung Washing Machines
Frigidaire top loader washer won't drain
The timer has went bad in your front load washer.Thats the reason why the unit is not draining properly. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure. You should go for a replacement.
Thank you !!
May 31, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire GLTF2940E Gallery 3.5 Cu. Ft. King Size Front Loading Washer Logo
60 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
