Hello I have a LG 8.2kg toploader washing machine model : WF-8071TTP ..the problem is the wheel inside at the bottom of the drum there is a screw and it keeps coming loose no matter how much I tighten it what can I do to fix this problem .??? Thanx
5 Suggested Answers
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
drsn
  • 42 Answers
SOURCE: I KEEP GETTING A dE
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
drsn777@hotmail.com for more info.
Posted on Dec 15, 2008
  • 713 Answers
SOURCE: My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Posted on Apr 10, 2010
  • 18 Answers
SOURCE: i have a lg fuzzy logic 7.5 kg WF-T755A washing machine that has stopped spinning and also stopped agitating in washing cycle
Call LG's support line, they have excellent customer service.
Posted on Apr 04, 2013
My top loader lg WF 8071TTP turbo drum does not drain and spin
Drain pump may be defective or something is obstructing it.
Nov 01, 2017 | LG Washing Machines
Hi I have a LG Fuzzy Logic 8.2kg WF-8071TTP washing machine. It washes but does not spin dry. Please heelp
may sound crazy, but sometimes the water pump gets clogged and does not operate, so will not spin. safety feature, I guess.
Try cleaning out pump.
Bruno
Aug 06, 2014 | Washing Machines
Lg wf 8071ttp
de is for door error not fit properly or door switch totally defective
call the technician for your safety and not to waste money.
Nov 01, 2013 | Washing Machines
REQUIRES MANUAL FOR LG FUZZY LOGIC TOPLOAD WASHING MACHINE MODEL NO WF-T7030TP
The service manual is hidden inside the unit or inside the console.
Oct 22, 2013 | Washing Machines
LG WF-8071TTP drum fills 3/4 and then drains unexpectedly
Either a main control board or you have a drain line problem causing the water to siphon out. If you house drain is lower than the washer water fill line or if your drain hose is sealed into the house drain line then you can have the water siphoned out of your washer. Check to make sure the drain line is not to far into your house drain pipe and that there is air around the drain hose where it enters the drain pipe, (not sealed tightley). If it is not the drain siphoning then you need a technician to diagnose the main control board and to replace it. Good Luck Appliance Specialists
Dec 14, 2009 | Washing Machines
Need schematic diagram of the washing machine assembly
A mechanical assembly diagram would have to be requested directly from LG.
May 18, 2017 | Washing Machines
I KEEP GETTING A dE ERROR ON MY LG TURBODRUM WF-8071TTP WASHING MACHINE PLEASE HELP
Dec 15, 2008 | Washing Machines
Need to remove object in drum
I have a Punch WF-C5856TC topload washing Machine. How can I remove odject that have been stuck inside?
Aug 13, 2008 | Zanussi Washing Machines
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
