Question about Garden
How to tighten my chaine on my jingling venom quad i have loosened the to hollding bolts but ddo not no how to strech the chaiiine
  • 211 Answers
SOURCE: cant find the screw to tighten chain on saw
Hi
You have to look from profile to the chain saw(clean it)
best regards savumihai71
Posted on Dec 10, 2008
dontbother10
  • 2220 Answers
SOURCE: after tightening the chain up on the bar it still
Keep the nose up!!!
Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Posted on Oct 15, 2009
dontbother10
  • 2220 Answers
SOURCE: How do I tighten the chain on my Remington 14 in.
Mitch if you attempted what is in the manual, and it is not working we would have to see and touch the saw to determine what has failed. If you loosened the bar bolts before trying the adjuster and it did not work, I suggest a trip to a local saw shop.
Chain adjustment pages 1, 8 and 9.
This is from a Remington OM
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107624%2001/107624-01-EL-8-OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Apr 03, 2010
  • 302 Answers
SOURCE: Hasqvarna 435 16"- bar nut loosens excessively
Put a lock washer on it to stop it from backing off.
Posted on May 19, 2011
  • 111 Answers
SOURCE: have a 450 with hand
New chains have a break-in period that might require more adjusting. When you fold out the knob, make sure you turn it counterclockwise to loosen the bar cover, then turn the wheel down (+) to tighten it, tighten the bar clutch by turning the knob clockwise, then fold it back in to lock the tensioning. Good luck.
Posted on Oct 06, 2011
Tightening chain
Tightening chain is performed by adjusting the bar. Two bolts generally hold the bar in place. Loosen these. Make sure that chain has enough play to easily move by hand. If it sticks, it's too tight. Then tighten the bar, check the chain oil, and cut wood.
Mar 25, 2015 | Garden
My chain is loose
LOL.....Don't panic...
There are 2 nutz on the chain/bar side of the saw.
You must loosen first, then locate the adjustment screw (reg flat screwdriver) on the end of the bar and next to the 2 nutz you loosen at the bar/chain.
Best to set saw flat and support the end of the bar/chain, tighten chain to a point where you pull on it and it can be pulled about 1/4 inch from bar with medium strength, "snug" I like to call it.
re-tighten your nutz after adjustment.
NOTE: I have found that when you support the end of the bar it raises it a bit, after you tighten your bar the tension increases depending on model of saw. Only takes a few minutes to play around adjusting and you will get it.
Nov 27, 2013 | Garden
Rf600r tighten chain
Chains are tightened by extending the chain bar. Loosen the two bolts holding the chain bar, move the bar away from the engine body and hold it upward (bar should be angled upward slightly) before tightening the bolts back down.
Nov 19, 2013 | Garden
Users Manuals
Loosen two bolts on chain cover,get screw driver and loosen tension on chain then remove two bolts and cover,then remove chain and bar,maked sure chain goes back on in same direction and tighten chain,then 2 bolts.
May 04, 2013 | Garden
How to bypass ignitino on gsx650f
Instructions
    • 1 Measure the chain's tension with a ruler. Move the center point of the bottom half of the drive chain with your hand. Take a measurement of the chain's movement as you push the chain up and down as far as it will go. The chain should have a free range of movement between 0.8 to 1.2 inches. If the chain's free range is greater than 1.2 inches, you need to tighten the chain. Alternatively, loosen the chain if it has less than 0.8 inches of free movement.
    • 2 Loosen the large nut on the left side of the rear axle with a 32 mm socket and a socket wrench. If more leverage is needed to loosen the nut, use a long-handled breaker bar.
    • 3 Loosen the chain adjuster blocks on both side of the rear swing arm with a pair of 10 mm wrenches. Hold the blocks' adjustment bolt's head steady with one wrench and loosen the bolt's lock nut with the other wrench.
    • 4 Turn both adjustment bolts an equal number of turns with a 10 mm wrench to adjust the chain's tension. Turn the adjustment bolts clockwise to loosen the chain, or counterclockwise to tighten the chain. Check that the edge of both chain adjuster blocks are evenly aligned with the adjustment marks imprinted on the swing arm.
    • 5 Check the chain's range of free movement again. Make adjustments as needed until the chain has a free range of movement between 0.8 and 1.2 inches.
    • 6 Hold the adjustment bolts steady with a 10 mm wrench and tighten their lock nuts against the chain adjuster blocks with a second 10 mm wrench. Tighten the axle nut to 72.5 foot-pounds with a 32 mm socket and a torque wrench. Check the chain's tension again.
Jan 15, 2013 | 2004 Suzuki GSX-R 750
How do you adjust the tension in the black and decker 16 inch electric chain saw. The chain is too loose...
UNPLUG THE CHAINSAW. if it's got a bolt or two on the right hand side loosen them, then turn the adjuster screw next to the bar until you have about 1/4 inch slack in the chain. tighten nut/nuts. if it's got tool-less adjustment loosen the cover bolt, turn the tensioner, tighten the cover bolt.
Mar 28, 2010 | Garden
How do i tighten the chain on 2002 yz250?
  • Loosen off the axle nut (B) until it is only lightly tightened. Wind out the chain adjuster bolts (C) evenly on both sides until you reach the desired tension. You will see the top of the chain rise as you wind out the adjuster bolts.on pic below
Once you reach the correct tension, make sure both sides are evenly spaced (using the marker grooves on the adjuster blocks). Squeeze the chain against the swingarm with your hand to hold everything in place and tighten up the axle nut.Tighten up the chain adjuster lock nuts. Now you're ready to ride!
  • Tighten up the chain adjuster lock nuts and thats it buddy measure the chain on the swing anr amr it should be 45mm slack on the swing and arm where the chain slider is 54159bf.jpg
Oct 03, 2009 | 2003 Yamaha YZ 250
How do I thighten the chain on a 99 Kawasaki ZRX1100
Near the back of the rear sprocket assy you will see a bolt facing forward. This bolt, when tightened, tightens the chain and visa-versa. To adjust the bolt, loosen the locking nut a just a little bit then adjust the bolt itself. It is best to make this adjustment while the rear wheel is off the ground, so you can spin the wheel and feel for chain tension. Once you have adjusted the chain tension to where you can just barely wiggle it 1/4" tighten the locking nut back against the frame. It is important to get this nut tight, as if it loosens, so will your chain.
Don't overtighten the chain as you will wear it out more quickly and wear down the sprocket teeth (expensive repair). Too loose and you risk a chain skip at high torque.
Aug 29, 2009 | kawasaki ZRX 1100 R Motorcycles
Yamaha warrior chain.
HELLO; Heres all you should have to do this,set your quad up on a atv jack or on a milk cartoon.Loosen the four bolts that hold the rear bearing carrior and back off your adjusters then push the carrier forward till it stops,relay your chain and adjust it leaveing a little slack, tighten your mounting bolts then, something I do, spin the rear tires to see if the slack is right if not loosen the bolts and proceed again with the proceedure turning out the adjusters a little more look at the chain as you dothis and you will see the slack in the chain on the top. GOOD LUCK.
Jun 25, 2009 | 2003 Yamaha YZ 250
The chain has come off my bosch ake 40-19e chainsaw, how do I get this back on?
first loosen the bolts that hold the bar in place. then find then loosen the adjustment screw. Once it is loose, the chain will go back on the bar. Then tighten the chain so there is only about 1/8" movement. (You will want to tighten the bolt so they are snug, when you are tighting the chain) Once that is complete re-tighten the bolts completely.
Jun 08, 2009 | Bosch Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
