Question about RCA 25414RE3 Corded Phone
Intercom I have 2 bases and I want to intercom from one to the other. When I try to, it shows ERROR or NO ANSWER. I read the manual and it said that when I try to intercom, the speaker is supposed to come on, but it doesn't.
    Novelist:
  • 201 Answers
I do not have any information on your specific phone but I'd like to try and help. Typically a multi-line phone set up like this would need a way to intercom between phones. I have not seen one that can utilize the same wires as the phone service but I also have not looked. It would also need each phone to have it's own identification (extension assignment). You only need two wires for each phone line but for intercom there most likely needs to be another pair of wires connecting all the phones together. I hope you have a manual. Look carefully at the section dealing with wiring up the phones to the phone lines. It should mention intercom at some point and what is required. Also, you can have up to 16 phones. Each phone must have a setting to choose a number between 1-16 or maybe 10-25, 100-115. By default these will all be at the same setting and you would not be able to intercom.
Posted on Jul 24, 2007
SOURCE:
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
How do i use the intercom on my Uniden dect. 6.0?
March 25, 2013 - INTERCOM INSTRUCTIONS
Here is the answer! Press the INTERCOM button one time.
The INTERCOM display will show on the screen.
Use the UP or DOWN arrow button to select the HANDSET number.
Press the MENU/SELECT button to ring the HANDSET selected.
Press the END button when done talking
Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
Switch Lines on hand sets
I had the same problem before. I found the answer by reading the Appendix C: Base Station Menu Tree in the munual.
If you don’t have the manual, here is the link:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027395.pdf
Go to System Settings/Automatic Line Select/Base Intercom 1-8, select the Manual Line Select. After this setting, when you use the handset to make the call, handset will prompt you to select the line.
Feb 05, 2009 | Siemens Gigaset 8825 Cordless Phone
How to use intercom between two handsets
For models with 2 or more
handsets included
Making an intercom call
1 Press {INTERCOM}
2 To page the base unit, press {0}.
To page another handset, enter its
extension number ({1} – {4}).
The destination unit beeps for up to 1
minute. Someone else can answer the other unit and talk to you.
3 To end the intercom call, press {OFF}.
Aug 18, 2008 | Panasonic KX-TG5632 Phone
Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Jun 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Intercom
make sure each and every phone has its own ID. That solved problems for me for all but one phone.
May 01, 2008 | RCA 25414RE3 Corded Phone
Lands Phones Logo
299 people viewed this question
Top RCA Lands Phones Experts
Marvin
Marvin
Steve Allison
Steve Allison
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
