Question about Motorola Programming Cable Gp340 Gp360 Gp380 Gp540 Gp550 Gp560 Gp580 Gp640 Gp650
How to program a GP380 and GP360
Encrypt
RADIO WILL SCAN BUT WONT STOP ON EACH CHANNELL
Contact Motorola Solutions.
Get Support
Mark Motorola Mobility Support
May 20, 2014 | Motorola GP360 Two Way Radio.
I use a Motorola XTS 5000 2 way radio at work. It displays a message "Key Failure"' and intermittenly beeps. It will not allow transmissions. Can I program a fix or does it need to be repaired?
It needs to be looked by a programming technician in a radio shop. "Key Failure" means that a secure encryption key has not been loaded into the radio and you have set the switch for using encryption to the "on" position. This switch is located under the channel switch on top of the radio and in your case it should be set to the "O" position and not the "O" with the line through it. The XTS radios can be programmed to retain the encryption key when the battery is removed OR to keep the key even if the battery is removed, so it depends on how your radio was programmed as well.
Mar 25, 2011 | Radio Communications
Can't uninstall PC guardian
You can try Revo Uninstaller. It should be able to remove the program correctly which will allow you to re-install it.
http://www.revouninstaller.com/
There is a 30-day trial available on the website.
Apr 05, 2010 | PC Guardian Encryption Plus Folders for PC...
Encrypting TI-84 programs I've seen this with other programs, but even as an experienced programmer i can't quite encrypt programs. By that I mean: if i see a list of my programs under the 'execute' menu...
The program is protected with a password, or it is archived. Unarchive the program. Under [2nd][CATalog] Press [2nd][ALPHA] U to jump to the first command in catalog that starts with U. Scroll down to Unarchive [ENTER]. Command is echoed on main screen, Feed it the name of the program and close parebthesis then press [ENTER]
Unarchive( program_name ) [ENTER].
I found out that reistalling the OS got rid of passwords on programs.
Hope it helps.
Sep 23, 2009 | Texas Instruments TI-84 Plus Calculator
Wireless connection is detected, but will not connect
If your other laptop is working fine, then have a look at the configuration of the wireless card and use the same configuration on the one that is not working.
Depending upon your wireless card make there is a program that enable you to setup the wireless card. Go to Start - Programs to locate this program. If your wireless card is built-in refer to your Acer manual.
Encryption is setup on the wireless router and these settings are also used to configure the wireless card. If the encryption is already setup, changing the encryption will affect your other wireless card, therefore all the wireless cards will need to be reconfigured with the new encryption to work with the wireless router.
May 09, 2009 | Acer Aspire One PC Notebook
Print is encrypted, nothing is readable.
If you are printing it from online, try copy and pasting the content to Word or Excel and print from there.
Oct 02, 2008 | HP PSC 2210 All-In-One InkJet Printer
Mail encryption
Hi, Couple of questions first, what email program is the person using who is sending the emails to you?
What email program are you using?
Who is your service provider?
Please let me know.
Nov 20, 2007 | Computers & Internet
Motorola Programming Cable Gp340 Gp360 Gp380 Gp540 Gp550 Gp560 Gp580 Gp640 Gp650 Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
