Question about NorStar IP Audio Conference Phone 2033 Extension Microphones (2 Charcoal) Cabling (NTEX11DA70)
2033 ip phone keep booting
I am connecting 2033 ip conference phone , after switch on , it keep booting in the following order
initializing the boot rom
loading boot parameretrs
again goes to initializing the boot rom Pabx is 1000E release 5.5
How can I get a second hand Mitel 5215 to accept an IP address?
Your phone needs an IP address in order to communicate. Normally, it asks a "host" for that IP. You need to be connected to the internet for it to connect to the normal host, and your router should be willing to give it that IP address. "DHCP" is how devices ask for and get an IP address.
May 11, 2015 | Mitel 5215 IP Phone
I have Nortel Polycom 2033 IP conference unit. When we have a conference, it's really bad sound quality. Is there anything that i can do? Thanks.
has it always been like that or it just started. this can be a speaker gone bad or an unstable line. a simple service may correct that effectively.
Jul 27, 2011 | Nortel Audio Conference Phone 2033...
How do i program ip 2033 on nortel system
when you plug it in, and the Nortel logo appears on the screen, swipe the three buttons that are under the display, with your finger, and that will get you into programming.
you will select following
Manual DHCP config? yes
Partial? yes
enter the IP address of your system
for port #: enter: 7000
retries: enter 5
for the rest of the programming select "0" till the end
Aug 23, 2010 | Nortel Networks IP 2033 Audio Conference
Dhcp server missing option 125 and 128, 5330 ip
My guess is that your DHCP server isn't set up properly, or someone has connected another Router to your network.
Jan 28, 2010 | Mitel 3000 IP Package
Mitel 5550 Console cannot obtain ip address.
Follow the proper boot-up sequence in the manual, and verify the PC boots up on the native lan first.
Oct 06, 2009 | Mitel Computers & Internet
Phones rebooting
there are many different problems that can cause the IP phone re-booting on a network, apart static.
Check if there are errors being reported by the pbx.
A common cause is an IP conflict due to a DHCP problem.
Check if the rebooting phone is connecting to data VLAN and then rebooting in voice VLAN, that means that is getting the right IP, and therefore is no DHCP problem.
If the rebooting phone is booting into vlan correctly, it can still be a different phone, with a bad MAC address, getting the wrong IP , and causing a different phone to reboot.
In that case you try isolating the problem by disconnecting switches one by one, and if problem stops, find the bad unit on the specific switch.
Mar 23, 2009 | Lands Phones
Discovering
Talk to your system admin. You have a Definity system, which is too complicated for online help. The phone isnt seeing either the license server or the Phone system. There is more than likely an incorrect IP address somewhere.
Jan 22, 2008 | Avaya Lucent 4690 IP Office Speakerphone...
Lands Phones Logo
94 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
