Question about Jensen VM9510 Car DVD Player
Jensen uv8 and amp hook up
I have a jensen uv8 unit and im trying to install a amp and subs where do i connnect the remote wire for the amp and where do i put the rcas since this unit has red and white rear and red and white front which one do i use
    Scholar:
  • 116 Answers
Remote wire from Jensen is blue or blue/white. Use Blu/white if there is one. . RCA's, for subs, use the rear if no subwoofer pre-outs are available. If unit has sub pre-uts, use them as the head ubit (stereo) would have a level that can be raised or lowered thus giving you more control over the input to the sub amp.
Posted on Jan 28, 2009
My jensen uv8 sub remote wire only puts out 9 volts y
It is probably going bad or there is a short.Just simply use a keyed on wire ( radio power is fine) for your sub amp turn on . In otherwords use a power sourde that only comes on when vehicle ignition is turned on. If you use one hot all the time your going to kill your battery, Good Luck !
Feb 09, 2015 | Jensen Car Audio & Video
Just bought jensen uv8 touch screen and installed speaker wires will produce no sound except for sub input on rca please help?
it could be a case while you or someone installing the unit could or might have blown out the speaker output of the unit
try taking the unit out connect the red(acc wire) yellow(constant wire) together connect the black(ground wire)
get a test speaker and see if u get sounds
Jan 26, 2010 | Jensen VM9510 Car DVD Player
Jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
May 19, 2009 | Jensen VM9510 Car DVD Player
DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
Jan 26, 2009 | Clarion DXZ545MP CD Player
Uv8 some seakers dont work in dvd/cd mode
You have the wrong wire hooked up to turn on your amplifire. You used the blue wire but need to use the Blue/White wire!! That is an amp turn on wire Thje blue one is for a power antenna and goes dead when you put in a disc. The tweeters play because they are hooked direct to your Jensen. You'll be jamming in no time.
Larry T
Winona Lae
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html IN
Jan 26, 2009 | Jensen VM9510 Car DVD Player
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
Jensen uv8
They have it installed that way because they have signed a purchase agreement stating they will not bypass. If they do, they can lose the line.
Do this and you will never have to mess with the E Brake or any toggle ever again...:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Jan 16, 2009 | Jensen VM9411 Car Video Player
Have no sound when the cd and dvd is played
you have a factory amp in your vehicle so what you need to do is take out the uv8 and make sure the remote wire from the unit " blue and whit stripe " is connected to the remote wire of the car harness.
the way you have it now is the power antenna wire " solid blue " the is connected to the remote wire of the unit
Oct 29, 2008 | Jensen VM9510 Car DVD Player
Amp to jensen uv8 hook up
to fix your problem cut the wire in half connect it to a ground and hot and there ya go it fixed my problem
Sep 15, 2008 | Jensen VM9020TS Car DVD Player
How do i hook up the r.c.a to the back of VM9312
try hooking up your rem wire I.E. blue/white wire to blue wire (not to power antenna) then check ground and power wire. never hook up power wire while car is on...you will blow amp
Mar 18, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
414 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
