Question about Ricoh Aficio Office Equipment & Supplies
Sc 611 error
3045
3 Suggested Answers
  • 9 Answers
SOURCE: sc 322
Another poblem with this machine is that the sync detect for the 400 dpi and 600 dpi could be off. Go into service modes by pressing the yellow clear modes key then pressing the numbers 1 0 7 then hold done the red stop key till you see the display change. Now go into copy sp, then hit the 2 in the window {drum}, next use the page down button located in the middle of the screen till you see the one that says 2109 LD Beam Pitch Adjust. Go to number 2109-8 beam pitch data reset. execute then go to 2109-1 and set it to 144 then hit pound. Now go to 2109-3 and execute. last go to 2109-2 and set it to 168 then hit pound. Now go to 2109-4 and execute. exit out of the service modes window. now try to run a copy and a print. If these fail the you either need to clean the laser assembly, a polygonnal mirror moror or laser drive unit.
Posted on Dec 16, 2008
SOURCE: ricoh aficio 3045 error code sc 541
Fusing thermistor open
Fusing thermistor disconnected
Fusing thermistor connector defective
Fusing thermistor damaged or warped
Fusing temperature –15% less than the
standard input voltage.
Change the thermistor.
Posted on Dec 07, 2009
How do i fix the error code sc 322 of my ricoh 3045 copy machine?
Have to open the Laser unit and clean the laser diodes carefully.
Dec 28, 2015 | Ricoh Aficio 3045 Digital Copier: 45cpm....
What is error sc-541 for ricoh aficio 3045?
it is a bad thermistor or thirmostat.. try to replace that one.
Sep 24, 2014 | Ricoh Aficio Office Equipment & Supplies
What is error sc-672
It is a problem with the controller. Or the controller board is not installed correctly or maybe a connector is not connect correctly. It could be the controller is bad and should be replaced.
Jan 18, 2014 | Ricoh Aficio 3045, 3035 Kit
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Ricoh aficio 3035/3045 error sc 672 not able to proceed to service mode also, kindly help me pls.
possible a bad operation panel replace or 672 B
After powering on the machine, the
communication circuit between the
controller and the operation panel is not
opened, or communication with
controller is interrupted after a normal
startup.
Controller stall
Controller board installed incorrectly
Controller board defective
Operation panel connector loose or
defective
690 A GAVD block I2C bus error
An error is detected in the GAVD
communication I2C control register of
the GABIC2.
I2C bus on BICU defective
691 A GAVD FCI block I2C bus error
An error is detected in the FCI
the GABIC2.
692 A CDIC GAVD block I2C bus error
An error is detected in the CDIC
the GABIC2.
700 B ARDF original pick-up malfunction
After the
Sep 21, 2012 | Ricoh Aficio 3045, 3035 Kit
Sc 395 ricoh aficio 3045
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Jul 05, 2012 | Ricoh Office Equipment & Supplies
Register Magellan RoadMate
Hello.
If you want to register your Magellan, You need to go to Megellan web site and create password.
Here is the link to copy and paste in your browser. http://www.magellangps.com/s.nl/sc.73/.f?login=T
Sep 29, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
My printer ricoh 2045 show an error sc 302,not print image correct
i have an error on my printer sc 302 how i can clear it easily .printer is ricoh 3045
Aug 11, 2011 | Ricoh Computers & Internet
How do i reset the error code sc542 on a ricoh 3045 copier
sc 542 is the fuser error code. follow the steps to reset the code.
press clear mode button once.
press 107
press clear/stop and hold for a while untill you see the screen changes to different screen.
press copy sp on the screen and off and then on the machine.
it should reset the code.
if it doesn't then either the fusing lamp or the thermostat is blown and needs replacing.
Oct 19, 2010 | Office Equipment & Supplies
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
20 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
