Question about Olympus FE-170 Digital Camera
Having problems turning the camera on and off
When I turn the camera (Olympus Fe-170)on, the lense extends as it should, however when the camera should normally show on the screen that I can take a picture it freezes and turns itself off after about 5 seconds. However when it does turn itself off, the lens doesnt receed back into the body of the camera. It stays extended out of the camera body as if ready to capture. I am finding it very hard to describe these symptoms of a fault in the camera. Is there a way I can reset the whole camera to see if that will help? Or obviously any other ways I can repair my camera? please may I have a solution asap. thanks.
  • 1 more comment
  • fe-170user Nov 26, 2007
    Battery is not the problem. How do I do a hard reset? If it is a short, how do I identify that AND how do I fix it? There is not a problem with moisture.
  • tendai brenda mazonde Nov 26, 2007
    when i turn on the olympus fe -170 camera the lences extend as it should and the light indicates its on but the screen would be blank /black .after few seconds it switches off without the ences going back into the body of the camera.at times i can view the pictures in the camera
  • lilmaiden Dec 11, 2007
    i have the exact same problem and i dont think it is the battery or anything of that matter because it shows a full battery icon. on my camera it seems as if, even though the lens does come out when i turn it on, it doesn't come out all the way. it seems as if it would just come out a tiny bit more it would work fine. i can press the green arrow for review and get the lens to come back in to turn it off. but i cannot get it to register that the lens is out.
Eureka - I found the problem you describe at least for my camera. I figured it was broken anyway, so why not take a look inside -- Well here goes - - -
As you disassemble you will see the seated LCD screen. Well, underneath the screen when you unscrew the screws holding it down are two ribbons holding the wires like in a computer. One of mine was disconnected. When I reconnected it - - everything started working! What a simple solution!
Note - take the batteries out before reassembly as you don't want to fry anything when the little screws slip out of your hand and fall into the circutry.....
Posted on Jan 01, 2008
    Problem Solver:
  • 32 Answers
Hi, it seems your battery is weak due o nonsuffient power this problem arises. If you had put the new battery still the problem there it means there is short circuit.let me know if you ahve any other query. thanks Sangita
Posted on Jul 24, 2007
SOURCE:
Camera freezing up
did someone spill some pop or anything near the camera? If so, then you'll need to clean that out with rubbing alcohol
Jun 03, 2009 | Olympus FE-170 Digital Camera
Morning. I have an Olymous FE-170 Digital Camera.
Sounds as if this may be a repair issue with the camera. You may want to call Olympus customer service to discuss their repair policy. Their telephone number is 800-622-6372 option 2 and then option 3.
Mar 10, 2009 | Olympus FE-170 Digital Camera
LCD FOR OLYMPUS FE-170 BROKEN CAN IT BE REPAIRED
my olympus FE-170 screen won't show any picture. All other things are fine and working the screen just won't show pictures taken or a picture i'm aout to take. the camera is about 2 years old i've had no problems with it till now. Can someone pleeeaaasssse tell me their is an easy solution to this.
Nov 23, 2008 | Olympus FE-170 Digital Camera
My camm!
I think thy will say you, replace lens unit. but lens is very expensive, so we can buy new one camera. I have the same problem, i found focusing lens wheel teeth slipping, no parts available, so i covered a gum coat on the teeth. but very difficultive
Jun 15, 2008 | Olympus FE-170 Digital Camera
Olympus FE-170 6.0 will not take pictures.
I had the same exact problem.The lens is not extending out fully or correctly, probably has broken or damaged gear or gears and needs to be replaced. Expensive repair done by Olympus. It is a very tricky and fragile repair on your own, requiring micro screwdrivers and soldering tool. I replaced my own lens but it was hard to find one.
Apr 28, 2008 | Olympus FE-170 Digital Camera
FE 170 OLYMPUS digital camera
its fucked up olympus sux i bought a sony cybershot 4000000 times better than that trash fe-210.
i trashed it destroyed it mutilated it till it begged for mercy
Dec 02, 2007 | Olympus FE-210 Digital Camera
Olympus fe 170
Olympus customer support This camera has a major fault and will be replaced if a year or less old- a repair prince will be like a new camera all over
Aug 07, 2007 | Olympus FE-170 Digital Camera
Olympus FE-170 Digital Camera Logo
389 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
