Question about Sony Televison & Video
Cannot see the picture on my tv
I have a 5" TV/radio/cd player. When I turn the tv on i cannot see the picture however you can hear it. The picture is somewhat black with a few white spots.
  • 2,071 Answers
This need an adjustment in flyback screen to make it higher so picture must seen.Open your TV go to the flyback there in the flyback body you can see a little rotary nab for "focus" and "screen"Just only adjust the screen a little until picture comes out.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 28, 2009
How do i program my sony dvd player dvp.sr200p to work on my philips tv
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Jan 01, 2016 | Sony DVP-SR200P DVD/CD Player
No sound from CD player. The turntable, radio & cassette work fine.
Can't get video to work so bose works with tv sound
Can't get video to work so bose works with tv sound I needed to reset the power on my bose and instead of unplugging the power cord, I unplugged the audio/video jacks because I couldn't see behind the
Oct 03, 2015 | GPX S7694 CD Shelf System
Soundlogic XT 5 in 1 wireless headphones will not receive audio from tv; only gets radio stations.
Did you connect the base/transmitter piece to the AUDIO OUT jacks on the back of the TV ? The radio you are listening to is the built-in FM radio/tuner. You need to connect the transmitter to an audio source (TV, PC, CD/DVD player, etc.) to receive sound from that source.
Jan 04, 2015 | Audio Players & Recorders
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
No sound for Icon TV (DVD Player)
Try to look for a switch under the dash it should be a toggle switch , what happens is that the switch turns on the Fm modulater that transmitts the sound of the Dvd to the station. If that is not turn then you will hear the dvd player. If you turn the switch on then you will hear the radio become more static, that means that the Fm modulator is working
Jul 06, 2009 | Icon F701WL 7 in. Car Monitor
When connecting dvd to hitachi 42hdm12a, screen said something was corrupted. Now, can't get picture. HDMI searching but won't get picture. help
1.Press [stop]button on DVD player to Stop DVD Playback
2.Press the [resolution] button on the DVD player.
3.change resolution to 480p
if you get a picture in 480P, continue your setup of the DVD player
If you still have no picture perform the next steps (stop at the step if you recieve a picture):
4. verify the video input of the DVD player to the TV and reselct it on the TV
5. use Video cable to verify the DVD player is still working
6 disconnect/reconnect HDMI cable to TV
7. power off/on the TV
8. power off/on the DVD player
7.
5. turn off TV then Tunr
Jun 24, 2009 | Hitachi 42HDM12 42 in. Plasma Television
TV TURNS ON BUT NO PICTURE
if your are able to open and close the dvd and able to hear the tv clike it means you secondery power supply is working you have the +5 volt and some other votege
i will look in the hv section and see if you have +120 v
you may have hv short
Nov 24, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
Dvd player
Hi, where you plug the dvd cables into the tv determines where the picture will be seen; Example, if you plug the dvd players yellow, red & white cable into the tv`s "input 1" then you go to the tv`s "input" or "tv/video" button and push those buttons to get "input 1" to come up on the screen and you`ll see the picture and hear the audio, it`s kinda like a file folder in your computer, you`ve got to find the file then open it to see the contents. If your tv is on channel 3 or 5 or whatever you won`t see the picture because the picture is in video not a tv channel
BMW Rider
Dec 12, 2007 | RCA F20352SF TV
Televison & Video Logo
118 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
