Question about Dynamode Computers & Internet
WL-700n-rxs wireless adapter overheating and cutting out
Connected to Sony VIAO laptop.Works, overheats cuts out. HELP
myob247
  • 1342 Answers
SOURCE: Support for Encore WL ADAPTER |ENUWI-SG USB 2.0
Download your Vista driver HERE
Posted on Apr 23, 2008
antiochpc
  • 1314 Answers
SOURCE: driver
Try this file, it is for the u356a for windows vista.
http://www.planet.com.tw/en/dl_file.php?fn=product/images/3173/DR-WLU356Avista[1].zip
Thanks and please take a moment to rate as fixya.
Posted on Nov 08, 2008
Alex_Woods01
  • 31 Answers
SOURCE: Locating the Wireless switch on my older Sony Viao Laptop
Hi there, my name is Alex and I am here to help solve your problem
On older models, the wireless switch is the Fun key (the key between the bottom windows logo key and control) with number 2. Press those 2 keys together and it should turn on.
I hope this info helps, please let me know if you experience any problems
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: WL-8313 Device Cannot Start Code 10
If your router has Detect unpnp or p2p devices on it disable it. That is what causes it.
Posted on Mar 02, 2009
Joed911
  • 4338 Answers
SOURCE: ps3 keeps cutting out wireless internet
You may have an IP conflict. Renew the IP on both the Sonys
At a command prompt,
ipconfig /release
it will come back with all zeros
ipconfig /renew
It should pick up a new IP address.
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the router may cause conflict with other routers within your network range. Recommend changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
I use the Asus WL-330ge as a network adapter for my HP Printer. This worked perfectly until I switched internet providers. I changed the IP on my printer to the same subnet as my new wireless router...
Let me state how I think you have this setup
Printer is Ethernet ---------- Ethernet (WL-330GE wireless adapter)
WL-330GE adapter >>>>>> Wireless >>>>>> New Router
eth_adapter_mode-d2r1efs5ntrf2rjwzg4ldeyi-5-0.jpg Diagram and mode is from
https://www.asus.com/Networking/WL330gE/HelpDesk_Manual/
ASUS WL-330gE user's manual in English
So I think you need to use Ethernet Adapter Mode !
The computer shown would be your printer
As you are using wireless you need to set up the wireless ssid and the wpa or wep encryption to match the new router I am guessing .
in section 4.3 advanced settings in the above manual link from ASUS.
Also the access point has an ip address by default as 192.168.0.1 255.255.255.0 you would have to most likely have 176.16.1.2 and the new router as 176.16.1.1 and the same subnet mask what ever it is maybe it is 255.255.255.0 then make the printer 176.16.1.5 subnet 255.255.255.0 or whatever subnet you use.
Make sure you log into the new router and alter the DHCP server to assign leases from 176.16.1.10 to 176.16.1.254 with same subnet mask.
Mar 31, 2017 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Driver needed for WL-700N-MRT Wireless USB Adapter
download software belkin 802 11g 54 mbps
Jul 15, 2012 | Computers & Internet
Wireless cuts out
Try moving closer to the router and see if it cuts out. If it stays connected you probably need a wireless adapter that can give you a stronger signal. You can purchase a usb wireless adapter for under $30 that will give you a strong signal and good connectivity at www.tigerdirect.com
Mar 29, 2012 | Computers & Internet
How do I switch on my SONY VIAO Laptop to accept wireless internet, which I know is working fine
Depending on the model you own, most Sony Viao laptops have a small slide switch along the front edge.
May 27, 2011 | Computers & Internet
Sony Vaio LT35E 1 long beep and 2 short beep on power on. no display. need help
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
It seems that there is RAM issue because of which you are 1 long beep and 2 short beeps refers on your Sony Viao laptop in such case the basic thing is to replace your RAM and youn't be able to get the beep sound again or else you can also Rub the golden foil of your RAM with rubber and try to insert it again. Hope it works for you.
May 24, 2011 | Sony VAIO LT35E T8100 2.1G 3GB 640GB BDRRW...
Connection problems with ASUS WL-167 G
Try going to "network and sharing centre" click "internet options" then click "connections tab" then "lan settings" check if it is set to "automatically detect settings". If this is clicked then maybe look through the guide or contact microsoft (if using windows that is!!)
Feb 02, 2010 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
How
go to control panel, performance and maintence, select hardware, and then select device manager, select your wireless card, then select details at top of box, that will give you the device id, cut copy and paste it in google for drivers. should find a site with that specific driver>
Jun 02, 2009 | Sony VAIO® VGN-N350E/W PC Notebook
Can not go wireless followed the instructions!!
First check able to see the light on the device while connected,If no light is lit re-connect the wireless adapter and restart your computer and then search for network...
May 21, 2009 | ASUS WL-138G Wireless Adapter
Signal periodically disappears
do you know if reciever WL-167G is using any type of password or wireless security protocol?
Is it possible that the router is set to only allow certain mac addresses to connect?
can you log into the router to check its records and wireless settings?
Mar 29, 2008 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
Computers & Internet Logo
26 people viewed this question
Top Dynamode Computers & Internet Experts
Prashant M
Prashant M
gharibeh
Level 1 Expert
Are you a Dynamode Computer and Internet Expert? Answer questions, earn points and help others
