Question about EliteGroup P4VMM2 Motherboard
Booting problem I reset the battery,problem is still available,I mean as soon as I am starting the computer,stops on first page and shows "checking NVRAM" and stays there,won't continue to boot the hard, do you know how may I get rid off this
  • 3,051 Answers
Hi there try these things first double check the ram and make sure that it is fully inserted unplug the powersupply cord to the motherboard and than press the on button on the computer than plug in the powersupply to the motherboard and boot the computer into bios and make sure that the ram is being recognized and that there is not a memory error there
Posted on Feb 16, 2009
  • 2,794 Answers
Do you know how to get into the BIOS setup? You can set it up for default in the BIOS settings. If it isn't saving them after restarting your computer, you should replace the battery to the motherboard.
Posted on Jan 28, 2009
Can't find the reset Password pin near the Battery
If you are prompted for the Windows password, this would mean that your Windows user name is password protected. This is separate from the BIOS password. Resetting the BIOS password on your computer will not reset your Windows password. If you are unable to recall your Windows password, or if you do not recall setting up one, try to leave it as blank and see if it works. If not, your other option is to restore your operating system through a previous restore point. **WARNING: Be sure to try to backup important files before you proceed as this can cause data to be lost.** Try to boot using your Windows Disc and perform a repair install or a full operating system reinstall. Another method is to use the factory restore option on your dell computer if it is still available. To do a factory restore, restart the computer and as soon as the Dell logo/screen shows up, hold down the CTRL key on the keyboard and press the F11 key a few times and release both keys. once you get to the screen where you can choose to restore to factory settings select Restore then press Enter. Let it go through the process and select FINISH once you get the message that it is completed .
Mar 16, 2015 | Dell Dimension 8250 PC Desktop
Machine boots and stops at compaq and then black srceen
Old computers can be cured with old tricks... No that doesn't sound right. You probably set your resolution so high that your monitor does not register.
A solution includes pressing F8 on boot until you hear a beep (That means, "I got it, stop pushing" and select Enable VGA Mode. This will enable basic video driver reset to 640x480; because your computer is so old, you should stick with 1024x768 as your highest resolution for a 15 inch CRT or LCD. Always check the manual of the monitor for what resolutions it supports. Your PC cannot even accept another monitor. Specs seem antiquated. Please invest in a new PC soon.
Dec 16, 2013 | Compaq Evo D31vm Pd1092 Pc - No OS -...
Dx2200 stops booting up. then shows a purple and yellow dotted screen !!! why ?
If your screen shows a clear picture to start with then it is most likely the video card driver. I don't know what you mean by no access to safe mode, but if you can get into safe mode you should be able to uninstall the video driver and restart. Safe mode is usually accessed by hitting F8 before windows starts so as soon as you see a picture on the screen start hitting F8 a few times until you get to the safe mode selection menu.
Dec 16, 2013 | HP Compaq dx2000 Microtower PC Desktop
I have an Acer TravelMate 4500 512Mb Ram an 80GB HDD, which doesn't run the operating system boot after bios boot. when I swich on it comes up a bios boot and after that the laptop screen's becomes...
1. Remove or Unplug any recently added hardware.
2. Remove and replace the battery.
3. Press and hold the power button for 7-10 secs to power ON the computer.
4. Try booting to windows Operating System in Safe Mode. (Press F8 key as soon as you restart).
5. Check if the Hard Disk is detected and listed with its capacity of 80GB in BIOS. (Press F2 as soon as you restart).
6. Reset BIOS to default values.
7. If computer boots to windows in Safe Mode, then perform a system restore to an earlier date.
8. Install any updates available for BIOS.
9. If Hard disk is listed in BIOS, perform system recovery using the recovery partition or the recovery discs.
10. If Hard disk is not listed in BIOS, contact any nearest service center to get the computer serviced.
Jul 23, 2011 | Computers & Internet
Black screen with info that pops up immediately upon booting up
That sort of message comes up when your computer is unable to boot to the hard drive. Those messages basically mean that it is trying to boot from a network, (which it isn't hooked upt to). Your hard drive could have failed, or your boot sequence could have been inadvertently changed too.
First, make sure your thumb drive is not installed in the laptop, as this can cause the problem too.
You can check your boot sequence by rebooting your computer, and entering the BIOS, usually by hitting F1 or F2 on start up. Tab over to the Boot section, and see what the boot order is: Usually it should be: CDROM drive, Then Hard drive, then removeable drives.
If this is ok, check and make sure that your hard drive is showing up in the BIOS on the main page too.
If not, it might be bad....
Hope this helps!
Apr 23, 2010 | Toshiba Satellite X205-SLI1 Notebook
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
Power chord shows green light but computer will not come on no sound moniter blank.think i need new battery?
First you need to check the power output of the power supply. Check the supply to tell you the output voltage and match that to the reading on a volt meter. This will give you the basic check for power.
If there is the corect voltage from the psu, keep it unplugged from the computer. Next remove the battery from the unit and hold down the power button for 10 seconds. This will clear all power from the unit and reset the power management. Plug the unit in without the battery and try to boot. Not many systems anymore require the battery to be in to boot. If this does not boot then put the battery in and give it a try.
If the unit does not boot, unplug and take a small pen and see if the power socket moves at all. If it does, it needs to be resoldered or replaced if the center pin (if one exists) moves on its own.
If the system turns on with or without the battery just for a moment then goes off, there is mostlikely a problem with the psu not having the ability to work under load. what this means is that the psu can output the correct voltage but once a load (the pc) is applied, the psu does out. This means the transformer it bad and you need a new power cord.
Without the model of the computer, this is what can be done without a service person physically looking at it.
Feb 01, 2010 | Northgate Computers & Internet
What we required for formatting first
this mean your computer has not any boot sector to boot, you need to re-install windows prior to formatting hard disk.
Jan 20, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Toshiba m300 charging trouble, stops charging when notebook is started.
sounds like the battery is showing that there is not much may need to do a couple of deep discharge cycles..
Oct 13, 2008 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
113 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
