Question about Samsung Televison & Video
Le40a656 fan noise - Samsung Televison & Video
Fan making noise on a 2004 Izuzu Ascender
all fans make noise.
which fan ,most cars have up to. 4 or more fans, some in rear seat.
try to point to and exact spot on car say in 1 square foot and say
xxx fan ,makes too much noise
Jul 01, 2014 | 2003 Isuzu Ascender
Fan noise indoor unit (asu12rlq) fujitsu
A high pitched noise from the fan unit, means a bearing issue from the motor. You must replace the fan motor to get rid of the noise.
Dec 17, 2011 | Fujitsu 24R1 Air Conditioner
Every 20 minutes, my freezer would make a crackling like noise. What does this mean and how can I fix this?
Refrigerators are not the most complicated appliance in the house, but it still takes a lot of parts working together perfectly to keep your food cold. If one of those parts breaks down, or begins to, you may start to hear new noises from your refrigerator. Fridges make some noise during regular operation, but if it suddenly gets louder or makes a different noise, it is a good sign that something is wrong.
Freezer Fan
Freezers can be located on either side of the refrigerator, or may be at the top or the bottom of the unit. If you hear a noise coming from the area in which the freezer is located, you should open the freezer and see if the noise gets louder. Any squealing sounds coming from this area indicate a broken freezer fan. These units are not designed to be repaired, and eventually one making a loud noise will break and need replacement.
Condenser Fan
All motors typically require a fan in order to maintain a safe operating temperature. Like the fan in the freezer, the fan that runs on the condenser can also break down and create a similar squealing noise. The location of the fan noise is what differentiates the freezer and condenser fan problems. If you hear a fan noise coming from the lower part of the fridge at the rear, it is likely the condenser fan causing the problem.
Action to do
Open the freezer to see if the noise gets louder. If the noise becomes louder with the freezer open, the noise is likely caused by the evaporator fan. If the evaporator fan is the culprit, replace it to get rid of the noise.
Pull the refrigerator away from the wall, and check the condenser fan at the back of the fridge. A metal panel may cover the fan, which can be unscrewed. Listen to see if the fan is the source of the noise. If it is, the fan may need to be cleaned or replaced.
Thanks for using FixYa.
Good day ! : )
Sep 07, 2011 | Refrigerators
Hi, everyone!!!1 my pro 320 get noising .....what happening///
Is it a clicking noise? Hissing noise? or maybe a grinding noise? A pc can cause many different noises. A clicking noise generally means the hard drive is failing. You'd want to back up your data immediately and get a new drive. Hissing can be a bad fan or CD/DVD drive that needs to be replaced. Grinding noises can also be caused by fan bearings going out. You would need to find out which fan it is, and replace that fan.
Mar 21, 2011 | Computers & Internet
The fan that is behind the bulb is making a loud noise for a few minutes and then the noise stops. We tried spraying the fan with WD40. ?? We can't seem to find a way to remove/replace this fan. Can't...
sometimes dust accumalates on fins of fans and causes rotation to deform and gets fan off balance causing noise .Also heat from lamp causes deformaties on fan and causes fan bearing to make noise.These fans can be replaced fairly easily
Jul 30, 2009 | Akai PT50DL24 Television
I have the samsung LE40A656 and when i watch itv channel (footbal
well, you can call up the network and get the picture clear or another sd card maybe
Jun 04, 2009 | Samsung Televison & Video
BOUGHT SAMSUNG LE40A656 LCD CAN,T GET SKY REMOTE TO WORK
I tried the closest model no. in the Sky list in the system setup, I think the code was 0840. Cover the front of the remote and press TV, then press red & select button until the remote led light blinks twice, key in the code 0840 and then press select.  Try the volume button and this should work.  If you get stuck go into interactive and system setup and select setup of sky remote and it gives you a list of makes and models, this is the closed one to the LE40A656 and works with mine.
Hope this works for you.
Jan 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Hitichi television will power on and than ...........
The buzzing noise would normally be either a fan or color wheel that is failing.
Jul 06, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
New samsung series 6 lcd tv brand new, but has a problem , the sound keeps lowering down to zero by itself for no reason, auto volume is off??
When watching football on my samsung le40a656 there is ghosting behind players. It is connected to a sky box via a scart lead, any idea's
Jul 01, 2008 | Samsung Televison & Video
Cpu fan noise problem
You should check and make sure the inside of your computer isn't dusty. Dust will wreak havok on fans and shorten their life. Plus it likes to build up between the fan and heatsink which will overheat your processor. Take the fan off and spin it with your fingers. I like to open the little sticker on the bottom and put some 3 in 1 oil to lubricate it. A smooth spinning fan is a happy computer. It also reduces noise that a dirty fan makes. Hope this helps you.
Sep 16, 2007 | Intel D915GAG Socket 775 Motherboard -...
Televison & Video Logo
249 people viewed this question
Jerry Greenberg
Jerry Greenberg
