Every time I switch on my new Kodak Hero 3 .1 I get error message "printer not responding" (105-100003 I can always restore the situation by restarting the print spooler and KodakAiO network discover
sandrew
  • 2961 Answers
SOURCE: "Error 1068 Could not start the Printer Spooler on local Computer"
Just to add to CoachTim's excellent solution, i find that removing the printer from the usb port as well as turning it off helps. But make sure you uninstall printer completely from add/remove programmes and check in the folder after that there is no canon printer listed. download this UK driver http://software.canon-europe.com/software/0024838.asp?model= Restart your pc before re installing and re connecting printer.
Posted on Feb 16, 2007
  • 320 Answers
HI,
right click on my computer -> select manage -> one should be services and something (or something like that) open that and go to services -> find the printer spool service and right click on it -> click on properties -> in the printer spool service properites click the "Start" button and also under a drop down menu change it from "Disabled" to "Automatic".... This is what you did right ?
Log in to Administrator account and try it there. If that doesn't work then install a fresh copy of Windows Xp. It should work now. Thank you.
Posted on Sep 07, 2008
SOURCE: Canon mp210 problems print spooler error
Error EP22
Posted on Feb 10, 2009
angelus316
  • 41 Answers
SOURCE: HP Laserjet 2200dn print spooler unable to connect
Have you tried a different driver eg. rpcs or another version of pcl?Have you checked your workstations services app to check if your print spooler is running?Also when you print a config page from the hp it will give you your network details.To eliminate your network grap a crossover cable and connect directly to the printer and test.Let me know.
Posted on May 28, 2009
SOURCE: Spooler crashes when printing random PDF's
Installing new drivers dind't help. But what I did is I checked print as an image from within pring options in Adobe Acrobat (you gotta go to "advanced" to find that check box), and then it worked.
Posted on Jun 12, 2009
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
How do I fix error code 6202
Code 6202 To Reset. Disconnect from power source wait 2 minutes and reconnect. This should work. I believe it is a modem problem. Your manual should cover this. Contact Kodak for further problems Most issues are correctable by the user and the user should first consult the user/operators manual.
Jul 03, 2015 | Kodak Office Hero 6.1
I have changed out my black ink cartridge and now it says Attention: Print head loose, missing or not installed correctly.
Had exactly the same issue - working fine until ink cartridge changed (kodak for kodak - not a copy). Then can only get 'print head error message'.
Multiple attempts to remove and re-install, power on/off etc. but can't shift the error message. New print head more expensive than a new printer!
May 06, 2015 | Kodak Office Hero 6.1 All-in-One WiFi...
When I clicked as always "Print" it showed me in the window "Printer" the "Microsoft XPS Writer" instead of my set up Kodak Hero 9.1. Please HELP!!!
Hi there
This can happen. Go to Control Panel > Devices and Printers.
Here you should see a hardware list of icons, including both your Kodak Hero and the XPS Writer. If the Kodak Hero is not there you will need to re-install the drivers and software from the disk which came with the printer. However, if it is there all you need to do is right click on the Kodak icon and from the menu that comes up click on "Set as default" and a green arrow should appear against the icon like this showing that the Kodak is the default printer and will show up first in any programme from which you print. 25277964-2fs4ue52shjy2lvm2lcqhtal-4-2.jpg
Cheers
Nov 10, 2014 | Office Equipment & Supplies
Why instead of my Kodak Hero 9.1 printer appears the Microsoft XPS Writer when I'm trying to print the document online?
go in to device and printers and change default back to ur printer. probs office or some other sw hijacked printers default setting
Nov 10, 2014 | Kodak Hero 9. Inkjet Multifunction Printer...
Printer is offline and wont print
Press Home, Network settings, wifi settings,then choose your wireless network within range. click your netwrok name and enter your security key..when the confirmation message appears, click ok, make sure that your kodak hero wireless printer software are installed on your computer.
click start menu,printers and faxes,right click your kodak wireless printer and set as default.
Aug 10, 2013 | Kodak Hero 9.1 Wireless Color Printer
Clearing Code 3527 from Kodak Hero 9.1
Hi friends,
I was able to solve this problem (error code 3527 on Kodak hero 9.1) by opening the printer entirely (dis-assembled), Checking the cartridge carriage assembly, i discovered that the belt that drive carriage assembly had a locker that was broken as such, the carriage assembly could not move in the direction as the motor drives the belt on.
I simply inserted the belt in position and drop a little drop of super glue to it, let it dry off.
Assemble my printer, and it was ok and is working.
Aug 01, 2012 | Kodak HERO 9.1 All-in-One Printer with...
ESP3 Printer purchased on 11th August 2009. Error message 'Printhead Missing'. Have Taken out and re-installed 3 times. Also fitted new KODAK cartridges. Your advisor AZAELRSL latest message is that the...
you need a new printhead. The ones that come with the printer seem to be faulty. Call KODAK technical support and they will send you one for free. Great service.
Aug 24, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have the Kodak 5300 All in one easy share printer. Less than a yr old. Also a Del computer with Vista Operating system, Less than a yr old. About a week ago decided to take the time to learn the kodak...
try using the system restore option on Dell computer.........as you have vista,,,click on the start button and type system restore in start search box and follow the on screen instructions and select yesterday's date and proceed.......should help:)
Apr 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
26 people viewed this question
jasbo
jasbo
