Question about Dell Genuine Ac Adapter 90w Latitude D 630 D 640 D 520 D51 La90ps0-00 D-family
90w-ac adapter dell d610 circuit diagram - Dell Genuine Ac Adapter 90w Latitude D 630 D 640 D 520 D51 La90ps0-00 D-family
Pyrhyc
  • 2028 Answers
SOURCE: Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Posted on Jul 26, 2008
  • 3940 Answers
SOURCE: Dell D610 only can run on battery, not accepting AC power or from
If not powering from DOCK, AC adapter and only from battery, since the Battery, DOck and adapter are known good, it is a matter of a motherboard replacement
Posted on Jul 10, 2009
  • 193 Answers
SOURCE: Dell Latitude D610 wont charge
the charging system on your motherboard has blown a capacitor, if it is still under warenty you should call 1-800-456-3355. to get it repaired.
if it's out of warenty, they can help you buy the right part
Posted on Aug 14, 2009
Testimonial: "thanks this was really helpfull"
  • 1043 Answers
SOURCE: dell d610 wont turn on ac adapter light is green
There is a small IC that Dell solders into their power supply as well as their batteries. When this parts fails you will have the type of problem you are having now. If you do a search on the web you will find a large number o sites that discuss this. Unfortunately there is no fix other than replacing your power supply. I had to do the same thing myself for the Dell laptop I use.
Posted on Nov 02, 2009
  • 192 Answers
SOURCE: My Dell Latitude D610 turned off and it did not
Your adapter is faulty. I've seen this a number of times...
Posted on Jan 22, 2010
Testimonial: "Thank you, probably there is a short anywhere in MOBO... I will follow your advise and buy another MOBO in eBay. "
Dell latitude e6410 chargin fault ,will run on dc adapter but shows not chargin ,battery not conected
  1. If the motherboard has ever been replaced, check the service tag section of the BIOS. If it is blank, enter the service tag off the bottom of the system. (The charging circuit will not work without it.)
  2. Also in the BIOS see if the AC adapter is identified or is listed as UNKNOWN. If the system cannot ID the adapter as a Dell Branded AC adapter 90w or larger, then the charger is again disabled. If unknown, check the barrel end of the DC jack of the adapter for the fine wire in the center, if broken or bent, then the adapter is not identified.
  3. Try with a different Dell branded 90w or larger D or E series adapter.
if all the above make no difference, and the Adapter is recognized, the battery may be at fault.
http://www.fixya.com/support/r3743571-long_will_battery_in_portable_computer
if the adapter is unknown, replace the adapter, unless it works normally on another system, and the other system's adapter has the same issue, in that case the motherboard is likely the issue.
Note: a 65w Auto/Air adapter will only charge the battery if the system is OFF
Jul 27, 2011 | Dell Latitude E6410 Notebook
My dell latitude d610 ac power is work is properly but battrey is not charging plz tell me soulition.
If the D610 works when attached to the AC Power Cord, it is likely that your battery is not capable of taking a charge and needs to be replaced. I have 2 D610 Dell Latitudes and they are very good laptops.
Please vote if my information is helpful or not. Recommend me. Thanks UAW 974
Jun 26, 2011 | Dell Latitude D610 Notebook
How do I get my computer to recognized my new ac power adapter?
The computer doesn't need any drivers to recognize an AC Adapter. If you have purchased the correct AC Adapter for your laptop then it should just work when you plug it in. If it does not then my guess is either you have received a faulty AC Adapter or the DC Jack which you plug into in the back of the laptop is bad.
I am assuming your battery is dead and when you plug it in and turn it on nothing happens?
You can also try taking the battery out and try to power it on with the AC Adapter plugged in.
The Dell Latitude D610 takes a PA-10 or PA12 AC Adapter. It's 65W or 90W
For 90 watt Adapter the output voltage on your AC Adapter label should read 19.5V and 4.62A
At least that's what the Dell brand reads so it should be close to that.
Jan 20, 2011 | Dell Latitude D610 Notebook
Dell Latitude states connect 65W or higher power adapter, eventhough, I have connected multiple 65W and 90W power adapters.
Hi Friend, In this case I believe, you can try updating the BIOS of the system and check if that fixes the issue. You can find the BIOS drivers from the following link:
hhttp://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D610&os=WW1&osl=en&catid=&impid=
But please make sure to connect the AC adapter while updating the BIOS
Also please make sure to select the Operating System that is installed on the system
Please let me know if it was of some help?
Thank you.
Jan 07, 2011 | Dell Latitude D610 Notebook
My Dell latitude will not re-boot
Did you check your battery LED light or Motherboard?
May be you need a dell latitude d610 battery?
This article can solve your ac adapter problem.
http://www.laptop-junction.com/toast/content/dell-ac-power-adapter-not-recognized
Nov 23, 2010 | Dell Latitude D610 Notebook
What would cause white moisture film on a power supply board? This is for a 51'' hitachi
Condensation could occur on any surface that was cold and then exposed to moist warm air but to create that inside a set?
If the white deposit isn't really moist, it may be the residue from a circuit board that was poorly cleaned. These are about 95% wave soldered on the underside and the solder has loads of flux floating on top of the solder to ensure a good flow of solder on leads and the board. The flux can produce a white deposit if it isn't thoroughly removed in a solvent bath. The component side of the board is mostly soldered via a 'reflow' method that reheats a tin/lead film on the component and the 'land' on which it is soldered. The amount of flux used in this process is quite small and rarely any flux survives even a lousy cleaning cycle. I've seen a bunch of circuit boards and have occasionally seen traces of flux irregularly present on them but never enough to appear like a consistent film.
If you have a film or deposit surrounding individual components, especially capacitors, this can be caused by the loss of electrolyte from a failing capacitor and is a sign of coming (or already developed) problems. Once this chemical (which does leave white deposits) has leaked, the capacitor is shot and needs replacement.
Mar 31, 2010 | Hitachi L32A403 31.51 in. HDTV LCD TV
LIGHT COMES ON AC ADAPTER BUT GOES OFF WHEN PLUGGED INTO NOTEBOOK
This is possibly an internal power Supply fault. take the battery out, plug in the adapter, IF the unit works now, you have A: A battery problem, or B: a charging circuit problem. If the unit still fails to work, the power supply in the PC has faulted. You need to get a "Quote: for a repair.
Mar 17, 2010 | Dell Latitude D610 Notebook
Dell Latitute D610 is no longer working under AC Power
Please check the AC adapter with another system and confirm if it is working fine. Else get it replaced.
Thank you for using Fixya
Oct 08, 2009 | Dell Latitude D610 Notebook
My Dell Laptop D610 wont turn on. It was on, I
Turn off laptop, Remove the battery and the power cable and press the power button for about 30 seconds.
Check for light on AC adapter.
Try with battery alone. Try with AC adapter alone.
Try with a different adapter of the same kind.
else the issue could be with the main board for which I would request you to contact the manufacturer.
Sep 11, 2009 | Dell Latitude D610 Notebook
Open Questions:
Support - Storage Solutions - Toshiba'call +1888784-9316 Toshiba is known to be a world class innovator and high technology product leader globally with its 24x7 major subsidiaries and affiliates worldwide. Toshiba launched their first laptop computer way back in 1985 and since then they have managed a record worldwide cumulative shipment of more than 100 million Laptops at Financial Year 2010. Toshiba laptops are sought after because of its quality and superior performance. Regardless of the superior features and all the convenience, you can easily be denied support by Dell Support for any issues that could mess up with your critical data backup, recovery and security. OS crashes are one of the major reason for critical data loss. The other contributors for data loss are accidental data deletion, Virus Attack and natural disasters. Unless, you have an updated backup, you can very well assume that you may have to part away from your precious data. DataAlign takes control of such situations and helps you Toshiba Support backup your data and restore it as per your requirements. DataAlign lets you select backup schedules and it then runs automatically as per the configured schedules. With Automatic Backup protection, DataAlign gives you peace of mind when it comes to data backup and restore. DataAlign's affordable TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus computer. And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any Toshiba Customer service issue that you may face with your TOSHIBA product. Toshiba Help Desk Number 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer.
Apr 24, 2018 | Dell Computers & Internet
Dell Genuine Ac Adapter 90w Latitude D 630 D 640 D 520 D51 La90ps0-00 D-family Logo
70 people viewed this question
Alun Cox
