Question about Danby DKC645BLS Compact Beverage Cooler
Keg cooler dropping below freezing (DKC644BLS)
My keg cooler suddenly started to drop below the regulated temperature. In fact, it has dropped to zero degrees and is no longer able to be controlled using the buttons on the front console. Also the LED is no longer functionind properly. I want to fix myself. What parts do I need to order and how do I install. Looking for answers soon, Very Thirsty
    President:
  • 331 Answers
Thirsty, you didn't provide a Make or Model number with your post. It's difficult to find parts without that information. However, given your symptoms, you should look closely at the control board on this unit. It is most likely the culprit. The flashing display gives it away! BUT, why did it blow out? 3 things could lead to that; 1.) shorted out temperature thermistor inside the box. (it is very small, less than an inch long... probably behind a protective cover. It tells the computer what temp the box is at by temp variable resistance values.) If I were working on this myself? I'd change it out along with the Control Board. 2.) Simple electrical failure of the control board (moisture, etc...) 3.) Unit suffered from a Power Surge. Do you have it plugged into a surge suppression device? If not, you should. Tracy
Posted on Jul 29, 2007
  • Tracy Farrell
    Tracy Farrell Aug 01, 2007
    Thirsty, you should contact Danby directly and let them know that you require a thermister and control board. They don't have parts listed online. You have to go through them, unfortunately.
    Here's their contact info.
    Vicky Bish
    Parts & Service
    Danby Products Inc.
    Tel: 1-800-263-2629 (Toll Free)
    (419) 425-8627
    Fax:(419) 425-1244
    Email:vbish@danby.com
    Web: www.Danby.com
    Good luck and enjoy the brew!
  • 51 Answers
New thermostat needed I would say. As for installing, thats a little more dificult & without writing a novel, but when you get your new part, examine it the try to work out how the manufacturer got it in!!!
Posted on Jul 25, 2007
I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
May 01, 2012 | Danby DKC646BLS Full Size / Pony Beer Keg...
Why won't my car start after the temperature drop
Either your battery is old do not carry charge from the alternator. Or the charge is leaked from your batter due to door or some light is open. Check basic doors and other stuff closed.
Jan 16, 2012 | 2002 Suzuki XL-7
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Magic Chef Dual temp. wine Cooler #MCWBC77DZC
I suspect the cooler can only actually regulate one of those temperatures and the other one just drags along behind. Perhaps the weather is now warmer and the cooler has to keep the motor on longer to keep cool. The unregulated bottom temperature ends up cooler as a consequence.
Either that or the opposite effect is doing it.
The answer might be to find a 61 degree place in your house to keep the reds.
Apr 28, 2017 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a BeverageAire keg cooler. I just put in a new CO2 cartridge and keg. The beer is not tapping...barely dripping from the tap
two things to check first at what pressure is the regulator set too? should be i thaink about 4 pounds. also what is the temperature inside of the cooler could the lines be some what frozen?
Jan 30, 2009 | Refrigerators
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Keg freezing!!!!
Same problem here. Can you give me their number? cheekychap@bellsouth.net
Feb 20, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Temperature on Keg Cooler (DKC644BLS) is dropping below freezing
Mine did this as well. last night the diplay read "LE" and the temp controls and the C/F buttons were unresponsive. I called Danby. Although I was on hold for 30 minutes, when they did answer they were very helpful. As mentioned elsewhere here, the touchpad has gone bad. You can order it right over the phone. The price of the touchpad is only $2 and shipping is $7. I ordered 2 of the touchpads (why not, right?) and the shipping was still $7 for the both. # for Danby is1-800-263-2629. Make sure your phone is charged.
Jul 23, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Compact Beverage Cooler Logo
552 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
