Copier konica 7033 error code f51-6 - Office Equipment & Supplies
jqsababa967
  • 145 Answers
SOURCE: I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Posted on Mar 14, 2009
jqsababa967
  • 145 Answers
SOURCE: I have a Konica 7033 copier with error code F-35-2
Access the 25 mode (power the machine ON, while pressing the 2 and 5 keys).
2. Press [1: Software SW].
3. Select software dipswitch 3-1 using the arrow keys.
4. Set the switch to OFF (0).
5. Press [Return] to end the setting.
6. Power the machine OFF/ON to exit the 25 mode.
good luck
Posted on May 05, 2009
firecontrol7
  • 6696 Answers
SOURCE: Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 19, 2009
  • 158 Answers
SOURCE: I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Posted on Oct 15, 2009
  • 6 Answers
SOURCE: konica 7040 error code F-34-3
Friend, this code refers to short-circuit the corona separation and transfer, check for accumulation of toner and do a cleanup in the corona.
Posted on Jun 01, 2010
How do i fix may konica 7033 displaying f52-1 error
F52-1 Cooling fan problem
or
F52 Main motor drive problem
Mar 27, 2015 | Konica Minolta Copier Toner 7033/7040...
Konica 7033 F-28-2
High Voltage issue have a tech come. Will have to have Old School knowledge you have a legacy Konica Machine.
Jun 12, 2014 | Konica Minolta Copier Toner 7033/7040...
Konica 7040 trouble code 35-1
Access the 25 mode (power the machine ON while holding down the 2 and 5 keys).
2. Select [1: Software switch setting].
3. Select software dipswitch #3 using the left up/down arrow.
4. Select bit number one.
5. Set the switch to 0 (OFF).
6. Press PREVIOUS SCREEN to end setting.
7. Power OFF/ON to exit the 25 mode.
Jun 09, 2014 | Konica Minolta Copier Toner 7033/7040...
ERROR CODE F-46-8 IN MY COPIER
I think you need to replace the front door interlock switch ( very common part ), and then take some time and adjust the bracket for a really good positve closure on the switch....leave the display panel off during this adjustment so you can get a good look at the switch closure. There is no factory adjustment on the bracket- you might have to bend part of the bracket to get a good closure. Open and close the front door a couple of times just to be sure and there you go. This front door interlock switch is a common failure on the 7033, 7040, and 7045's and will give you all kinds of crazy symptoms.
May 11, 2014 | Konica Minolta Copier Toner 7033/7040...
Konica 7040 trouble code 51-4
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Nov 07, 2012 | Konica Minolta Copier Toner 7033/7040...
F-36-2
Jeruel:
The Error code F36 indicates an error in the fuser, (the part of the copier that fuses the toner into the paper. Unless you are a copier technician, I would leave this one alone and call for service. An improper repair to the fuser can cause a fire as the fuser works at 375+ degrees. (That's why the copy is hot when it comes out of the machine.
Aug 11, 2012 | Konica Minolta Copier Toner 7033/7040...
good luck
May 04, 2009 | Office Equipment & Supplies
Konica 7033 error code F-51-4
my machine incounter problem F 51 - 4 KONICA 7040 ,pls help to solve this problem.I already done checking the drum cart.
Sep 18, 2008 | Office Equipment & Supplies
42 people viewed this question
k24674
jasbo
jasbo
