Question about Stihl Garden
No spark new plug - Stihl Garden
  • Stihl Master
  • 1,807 Answers
Could be an Ignition module problem or on/off switch fault(earth)
Posted on Jan 26, 2013
How do I change the spark plugs
if you follow the spark plug wires they should lead you to the spark plug. when you remove the spark plug wire you may want to give it a little twist just to break it loose from the spark plug than pull the wire off. than you just use the right size spark plug socket to take the old plug out and to put the new plugs in once the new spark plug are in just push the spark plug wire back on. make sure you gap the spark plugs right if you don't you could end up with a misfire in that cylinder also be careful not to crack the new plugs if you do you will need to get another new spark plug.
Jul 02, 2015 | 2005 Hyundai Tucson GL
How to change the spark plug
1 Spark Plug Spanner 1 New Spark Plug
Pull H.T Lead off the top of Spark Plug, You need Spark Plug spanner to do the job. Untighten Anti Clockwise, Check Gap is correct on the New Plug ! Hand Turn the New Plug into hole, carefull as threaded. Tighten up , till tight , do not over tighten or you might strip thread, Put cap back onto Plug . FINISHED
Mar 14, 2015 | Garden
Spark Plug Cover keeps popping off Spark plug when under load causing trimmer to cut out on my RYOBI RBC254FSDSN
Sounds like your spark plug boot has gotten soaked with oil or some other contaminent. Replace spark plug boot with a new one.
Jan 03, 2015 | Ryobi Garden
How to change the spark plugs on my 2009 Hyundai Sonata 4 cyl.
remove 1 spark plug wire from the plug. Find a socket that fits the spark plug and connect it to the socket wrench. Put the socket on the spark plug and turn counter clock wise until the old spark plug is removed. Check the gap on the new replacement plug ( make sure you have the correct plug first). Put the new spark plug into the hole that the old 1 came out of and turn clockwise by hand making sure it is in straight, then tighten it clockwise until tight.( WARNING: DO NOT OVER TIGHTEN THE PLUG OR YOU WILL BREAK IT). replace the spark plug wire. repeat the process with the other 3 spark plugs. Start the vehicle. If you are replacing the wires, take off 1 wire at a time, match up the size and replace the old with the new.
Dec 27, 2014 | 2009 Hyundai Sonata
1997 harley davidson flhtcui no spark
Hi Anonymous, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Battery voltage below 9 volts, loose or broken battery cables especially "GROUND" cable to frame.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, MAP or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm.
For a prime suspect please visit the website below. Good luck and have nice day.
Apr 04, 2012 | Harley Davidson Motorcycles
How to replace a sparkplugs for a mitsubishi montero xls 2002
    • 1 Cool the engine before attempting to remove any spark plugs.
    • 2 Remove the spark plug wires located across the top of the Eclipse model's engine. The spark plug wires connected to the spark plugs are the flat circular ends. Grab the wire around the circle and twist to unlock the wire. Lift up on the wire to remove it from the engine. Some models with ignition coils above the spark plug may require you to unhook the wire from the ignition coil to remove the wire.
    • 3 Drop the socket with the extension and socket wrench attached into the cylinder well and on top of the spark plug. Turn the socket wrench to unscrew and pull the spark plug out of the engine.
    • 4 Spray silicone spray into the cylinder well and onto the new spark plug threads.
    • 5 Insert the new spark plug into the socket with the threads sticking out. Slide the socket into the cylinder well and gently turn the wrench to the right to thread the spark plug into the cylinder head.
    • 6 Use the tension tool to test the tension or torque of the new spark plug. Set the tension to the specifications listed on the spark plug package.
    • 7 Reattach the spark plug wire to the new spark plug.
    • 8 Continue this process with the other spark plugs. Be sure to only complete one spark plug replacement at a time.
Sep 20, 2011 | 2002 Mitsubishi Montero
My kawasaki 300 four wheeler kef has problem with the spark it has a little bit of spark needs more.
The battery may be going bad. Try new spark plugs first. Carbon on the old plugs can rob spark.
Mar 30, 2011 | kawasaki KLX 300 Motorcycles
How to replace spark plugs in a kia sorento
The 2006 KIA Sorento is a smaller SUV with a 3.5-liter V6 engine. This engine uses six spark plugs to run the engine properly. There will be three spark plugs on each side of the engine. All six spark plugs will need to be changed at the same time to ensure that all six are working equally. The spark plugs are in plain sight on the right and left side of the engine and have rubber wires connected to the top of each one.
  1. 1 Insert the edge of the spark-plug gapping tool under the meal arm in the center of the one of the new spark plugs and turn the gapper until the number .038 is in the center of the metal arm. Repeat this for all other new spark plugs.
  2. 2 Open the hood of the 2006 KIA Sorento and remove a rubber wire from one of the spark plugs. Use the ratchet and spark-plug socket to remove that spark plug from the engine.
  3. 3 Insert the new spark plug into the hole where the old plug was. Hand-tighten the new spark plug until you are certain it is seated properly, then tighten it further using the ratchet and spark-plug socket. Replace the rubber wire to the top of the new spark plug.
  4. 4 Repeat for all other new spark plugs. Once you have replaced all six spark plugs and replace the rubber wires to the tops of them, close the hood.
Jan 21, 2011 | 2006 Kia Sorento
Spark plugs
I believe you will need a 3/8 spark plug socket. removed spark plug wires. remove spark plugs and install new plugs. Tightening torque is 27 Nm then reinstall spark plug wires with corresponding cylinder left to right goes 1-4.
Sep 07, 2008 | 2003 Mini Cooper
Garden Logo
24 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
