Question about Kodak EasyShare Z740 Digital Camera
Camera will not turn on
I have checked and dooubled checked the batteries multiple times. The batteries are good.
I read up about it and turns out that that model turned out unsuccfull cause it was verry easy to lose data wipe the system cause a code error and dropping usially stuffed it up 2
but try this anyways if u have a docking station plug it in than make sure its off first then turn on
make sure u conect it to the computer when it reads the camra on computer then remove it then replug it back in and open the camra to the computer leave it runing on for 5 or 10 mins if your camra is stuffed it will show this message
An error occurred in the io-library ('Could not claim the USB device'): Could not claim interface 0 (Operation not permitted). Make sure no other program or kernel module (such as sdc2xx, stv680, spca50x) is using the device and you have read/write access to the device.»
or u simply have jammed the lense and broken the motor works in the camera
jaming the lens can cause a programing loop in the hardware and software i think the best way to fix it
would be to incert the CRV3; 2-AA lithium charger in and out a few times to stop the programing loop by a certian amount of electric voltage current that will shock ur programing system to automatically correct its self
you should have a flash memory built in and a SD/MMC card make sure that its incerted it will help stop any programing functions by automaticly sending data to the hard disk flash memory forcing the program to work
basickly try forcing programs to pick up the camra software like the printer dock the usb cable and the av cable
if none works it basickly stuffed
thoe u can hack it but seriously if u dont knw what ur doing don try lol
so yeaa thats about all i can do for u
if you understand programs and software and can hack heres a link youll just have to search in for the latest post on the download link
http://forums.dpreview.com/forums/read.asp?forum=1011&message=20329748
this allso allows u to do a load more with ur camra like super zooming , auto face detect , more video effects ,extending a flash memory to ur internal memory and **** like that lol
write bakk
l8ers aii hope it works
Posted on Jan 30, 2009
Green light goes on when I turn camera on, but 3 red lights flash when I shoot & nothing happens. I tried changing multiple batteries, all alkaline. No luck yet. Any ideas?
The 3 flashing red lights indicate low battery power! This could be because of low battery power (all 4 batteries must be good), the battery contacts in the camera are poor, the make of battery being used (try different make of battery)
Aug 05, 2015 | Fujifilm Instax MINI 7s Instant Film...
I bought this camera only a couple of months ago. I used it at a maximum three times, but at late it wont charge. I have multiple USB chargers and have used them all, but still wont charge :(
Hi, Check the connections for tightness and use a volt/ohm meter to check for charging voltage. Anywhere between 6v and 12v. If you suspect charger, replace with same kind and Voltage output.
Also check battery(s). replace if dead. After many battery uses. They can have an internal discharge and will not work properly any more.
Good luck.
Jun 06, 2015 | Olympus VG-170 Digital Compact Camera -...
Samsung ST90 help
Return to seller as faulty goods
Aug 22, 2017 | Samsung ST90 Digital Camera
Samsung camera still not working
I personally have had great luck with the Kodak Z650. It's an inexpensive full featured camera that provides a good zoom ratio (10x optical + 5x electronic = 50x zoom), the convenience of a charging dock that lets you connect to your computer AND charge the camera by simply dropping the camera into it, and plenty of available accessories. I have two of these cameras and I recently gave one to my daughter and her husband. Kodak.com is a good source for these (new & refurbished), and eBay is probably an even better source. AVOID the Kodak printer dock though. Quality is poor, and they are prone to multiple problems.
Don't give up on the Samsung yet, though. The problem you describe is frequently battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing into the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Cameras
PLEASE HELP.
someone595,
Don't panic, keep in mind to turn off the camera before you remove the SD card or change lenes. Charging the battery shouldn't take too long put it back in make sure the lens is properly locked in place, put in the SD card in then turn it on and you should be good to go. let me know I'll check back in an hour to see if that helped.
randy320sgi
Jan 06, 2009 | Nikon D70s Digital Camera
Sir my sonyDSC-40 Camera dot't power on. In power butten pressing time only one time bliking green LED.
Turn off the camera, remove the battery pack. Allow the camera to remain without power for 30 seconds. Reinsert the the battery pack. Turn on the camera.
Please make sure the Battery is fully charged before performing this steps.
Also try changing the Batteries of the Camera. "AA" NiMH, "AA" Alkaline, "AA"
Nickel-Metal Manganese are the compatible Battries for the Camera. Hope it works!
Dec 01, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Won't turn on, only flashes a light
use rechargable minnimum 2500mah batteries -----solved
Nov 05, 2008 | Pentax Optio E60 Digital Camera
My camera wont turn on
Yep you need to get an AC adapter. Can get a multiple voltage one at electronics store cheaply enough. Cheaper than getting an actual Fuji one that is for sure..
Then try to download the firmware for it from Fuji and that should do the trick... If not like you said time to get a new one.
Good luck.
http://www.fujifilm.ca/x3719.xml
Sep 27, 2007 | Fuji FinePix A120 Digital Camera
Depleated batteries?
But is the camera working? Check out the HP technical Support team-there may be an issue that are aware of and a reworked camera will come winging your way If the camera is more than a year old-repair is not an economic option
Jun 18, 2007 | HP Photosmart M417 Digital Camera
It won't turn on!
If you are sure you are running the camera properly. And you put good fresh batteries in making sure the batteries are in the right way. You might want to find the receipt and return it to the store. Cameras can get pricey fast to repair.
Jan 03, 2007 | Kodak EasyShare C533 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
93 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
