Question about Garden
Goddards white horse oil embrocation - Garden
What caused 19 horse Kohler to belch white smoke
white smoke fuel blue black white smoke oil over fill oil will cause it getting to much fuel will cause it check carberator check oil
Sep 02, 2014 | Cub Cadet Garden
Tip
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
on Sep 23, 2009 | 1998 Ford Explorer
Tip
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 19, 2009 | 1987 Jeep Wrangler
I am receiving Taegan Goddard's Political Wire on Twitter with my picture & name & I want it to stop but cannot figure out how. I've blocked him, but they still keep on coming.
threaten him with libel, he might not care but twitter certainly will and they will say bye bye to him if he doesn't budge, see this site for inspiration
Jan 07, 2014 | Computers & Internet
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
Columns are Color, Function, Mark on the plug.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 1981 Ford F 150
What is regal medicated oil & embrocation and how do you use it?
Hi
There are many oil that are medicated and used for certain conditions. I recon you need to rub the oil onto the infected area.
for example: If the oil is needed for your leg then simply pour a little on your hand and massage the oil on the leg.
Thank you
Feb 05, 2013 | Health & Beauty
How often should I groom my horse?
You should be grooming your horse lightly every day. You should brush its hair, remove burs and make sure that it doesn't have any caked on mud. If you over groom your horse daily, you can accidentally take away some of the natural oils and minerals his body needs to stay healthy.
Jan 14, 2013 | Equestrian
08 18 horse huskee riding mower it will start and white smoke will poor out exhaust and will not stay running
sounds like the carb needs to be rebuilt the needle valve doesn't seat then overflows gas into the crankcase smell the oil
Apr 24, 2012 | Garden
Wiring towbar for t25 volkswagen
Hi Paul,
This should help,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
Sep 15, 2009 | 1986 Volkswagen Wagon Camper
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
