Question about Lexmark X1270 All-In-One InkJet Printer
Printer will not print
My lexmark X1270 will not print, it makes all the noises, moves the paper through, everything it's suppose to do but the page comes out blank.
  • 21 Answers
Create a New User Profile like Test Account and try printing from that account and check if its printing from there..
How to Create a New User Account ?
XP
Start>Control Panel>User Accounts>Create New Account it shoul be admin...
Vista
Start>Type User Accounts in Search>Click User Accounts>Manage Another Account Create New Account..
If its able to print fine in new account then that means the profile of your old account is corrupted..If its doing the same thing in new account also ..Reinstall the Printer driver in the following Method..
Disconnect the Printer
1.Click>Start>Control Panel>Printers and Faxes and delete the The Printer that you are reinstalling the driver for delete all if there are more than 1 printer of the same.
2.Go to Control Panel>Add/Remove Programs> Uninstall the Lexmark related Programs
3.Restart the computer
4.Start > Run > Type in "cmd"
5.now you will have command prompt Type this and hit enter "net stop spooler"
6.Click>Start>Run Type in "C:\WINDOWS\system32\spool\drivers" Hit Enter
7.You will have the following folder open rename the W32X86 folder to W32X86.OLD
8.Restart the computer
9.Insert the Lexmark CD and start installing the software Note : Connect the Printer only when the installation is prompted to connect..
This should defnitely take care of your problem..
Note if you are using vista try this first
Start type msconfig open that go to tools tab and disable UAC and restart and check..
Posted on Jan 28, 2009
My Lexmark X1270 printer at one time worked, everything was good, then when I put a new color to black will not print any other color or a black color, print only a little pale, almost do not see anything...
Lexmark products work best with genuine supplies. Lexmark does not recommend the use of refilled, remanufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
You can try to clean your cartridge nozzles using the Lexmark software on your computer. From your computer, go to Start menu > Programs > Lexmark X1200 Series folder > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If that does not help, maybe it would be best to replace your supplies with genuine cartridges.
I hope this helps.
Dec 02, 2011 | Lexmark X1270 All-In-One InkJet Printer
Not printing.
trying to photocopy paper / buttons not working coming out blank
Mar 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
Black will not print properly
your cartridge is about 100 pages of ink. Try to buy #16 black and #26 color for best results and economy, since #16 have about 250 pages resource.
Mar 07, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 Not printing.
Did you put the right numbers of the cartridges?
Sep 30, 2008 | Lexmark X1270 All-In-One InkJet Printer
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270
You might go to the Lexmark website and download the drivers for that model directly .
Sincerely , Hammerman
May 14, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 printer power button blinking won't print
I had the same issue with my Lexmark X1290, I solved it by opening up the device, so the ink cartridges should pop, they didn't so I pressed the power button to switch it off, and then switched it back on (with the device open!) and all the paper flowed out, the flashing stopped and it could print again. Good Luck!
Feb 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
X1270 - flashing light.
sounds like the paper jam might have stripped some teeth off the gears in the printer or the motor might have failed have a visual look at the gears that pull the paper through if broke measure it and tell me how many teeth it has i might have one, or even the motor i have extra printers lexmarks for parts.
Dec 08, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
