Numorse pro installation - Computers & Internet
Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Apr 23, 2011 | Apple Computers & Internet
Installed pro tools 8 on macbook pro. when i try to open pro tools it says the hardware cannot be found. mbox2 is connected but the usb light is not on.
I had this problem as well... If this is a 2011 macbook pro you have os 10.6.7 which is not supported by avid at this time. We actually need to down grade to 10.6.6. You installation cd with your macbook pro is 10.6.6, so you'll need to install that, then go to the avid website and download pro tool le 8.0.5. Everything should work fine just don't upgrade to 10.6.7 until it has been approved by avid. If you need detailed steps look at the avid forum for pro tools. Step to uninstalling and installing the os can be found on youtube.com... Do not have your mbox plugged in when you install pro tools. I hope this helps!!!
Mar 29, 2011 | Digidesign Mbox 2 Barebone
Installation manual for fargo pro l printer
Check page 22 of the Pro User's Guide, you can download from FARGO support pages. Here are the links to the available manuals for your printer:
Sep 06, 2009 | Fargo Pro L ID Thermal Printer
I have a thinkpad t20 and a 570e, both with
The IBM Recovery Disk that comes with those laptops is set up for Windows 2000, not Windows XP Pro. The answer is No, you cannot use the IBM Recovery Disk for them, if you install Windows XP Pro.
However! You will have a recovery disk, because you will have the Full Installation disk for Each laptop. Windows XP Pro Full Installation Disk.
(Microsoft Users License states "One genuine copy of Windows per One computer" That means you need Two, genuine copies of Microsoft Windows XP Pro)
Sep 06, 2009 | IBM ThinkPad T20 2647 Notebook
How to repair workstation, os are win2000 pro in workstation
do you want to reactivate the win220 pro installation on the harddisk which now you cannot access?
insert win xp pro install cd and run the repair process
or
if you have partioned the harddisk, simply do a new install on another partition, mark this active and now you should be able to boot up and access the old installation.
copy the non-microsoft programs plus personal data (everything that is not in the windows folder) to the new installation,
then run every single program from the new installation
good luck
Apr 18, 2009 | Computers & Internet
MacBook Software Updater - continually prompts to install an update
You're probably not actually flashing the firmware, but downloading the utility to do so. Follow these steps:
1. Quit all other open applications. Open the MacBook Pro EFI Firmware update which is in your Utilities directory
2. Click Shut Down in the MacBook Pro EFI Firmware Update window and wait for your computer to shut down.
3. Press and hold the power button on your MacBook Pro until the power indicator light flashes repeatedly, then release the power button to begin the update.
A status bar indicates the progress of the update.
Important: Do not interrupt the update.
Your computer restarts automatically when the update is completed and opens the MacBook Pro EFI Firmware Update.
4. Click OK, if the firmware is now up-to-date.
Apr 29, 2008 | Apple MacBook Pro Notebook
Windows Vista and Office Pro 2003
hi, yes you can install office 2003 while you already have office 2007. you just need to change the installation directory when you launch the setup for office 2003. change it into something apart from what office 2007 already is installed in. so what you're trying to say is that you should be entitled to an upgrade to office 2007 if office 2003 doesn't work? i would maybe think so... but no solid answer for that one.
Sep 09, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
