Question about Maytag EPIC MFW9700S Front Load Washer
Water Leak from the Front Door of our Maytag Epic MFW9700S
A small amount of water (about 1/8 cup?) leaks from the bottom of the front door of our Maytag Epic 9700S washer. It seems to happen in the beginning of washing cycles when the water is filling the drum as it is spinning. The washer is a little over a year old and just out of warranty. This has actually been going on for a few months (I wish I had fixed it while under warranty!)
I suppose the big rubber gasket around the drum that meets the door is suspect, but it doesn't seem particularly easy to replace, so I thought I'd ask here to see if others have seen and fixed this problem.
I don't think it's related, but in the past, the washer had an FH error, which I fixed by replacing the spigot, and a F2 error, which I fixed by removing a baby sock stuck in the drain filter at the bottom of the machine.
  • 2 more comments
  • campbex Mar 07, 2009
    My Epic Z was purchased about 4 months ago, but only installed and used for the first time in our new condo 2.5 weeks ago. On our 3rd or 4th use of the washer, it leaked from the front across our kitchen floor. Not a huge leak either, but enough to be worried about. Should we simply be calling service?
  • Anonymous Mar 07, 2009
    my problem is the door gasket wont stay on.is there a glue or way to seal this?
  • captn_carrot Mar 14, 2009
    Shaggyone,
    Around here, the Maytag repairman wants $300 to come replace the $29 gasket. Which makes me kinda realize why the one on the commercials is so lonely. LOL.
    Given that's a 1/3 of the price of a spanking new machine, was your time and effort worth that, or would it still been better to cough up the C-notes?
  • John Doe Apr 01, 2009
    Shaggyone was right -- it was the gasket -- but I wound up fixing this myself. There was a small portion of the gasket that had been ripped out. Probably got caught on a zipper of clothing item that was being pulled out. The missing piece was about the size of a quarter, and from the part of the gasket that rests against the see-through front window. So water was seeping through the front door at the rip.
    A replacement gasket was going to be about $90-100. Plus it looked fairly complicated to install the gasket. Lots of pieces had to come off.
    So I decided to try to fix it myself. I went to a hardware store (Home Depot) and got flexible rubber cement (cement that has some flex once it dries) and a piece of rubber/plastic (I walked around the aisles looking for the right material, and settled on a long piece of flexible plastic they sell in the door department -- I can't remember exactly what the plastic is for). I cut out a piece of plastic the same size as the missing part of the gasket, and glued it into place, then ran a test wash, and it's been working fine.
    Problem Solver:
  • 5 Answers
The water leaking is most likely the gasket. It may have a little rip or something making it not seal. Im not sure about Maytag but on our GE we had to slide the the top back to remove some screws then (I believe to was for the control panel) Then we removed screws for the door and the front of the washer. When that was done you have to remove a round clamp that holds the gasket on. Then replace the gasket.
My suggestion is to have a appliance repair come and do it. Its a pain to do, at least it was for me.
Posted on Jan 28, 2009
Door leak
On the glass make sure there is no hair at the bottom in the groove where it mates into the plastic but you'll probably need to change the bellow the round grey seal
Jan 19, 2014 | Maytag EPIC MFW9700S Front Load Washer
My maytag epic z is leaking from underneath
Remove the front bottom panel. Should be three 1/4" screws on bottom lip of panel. See if you can tell where leak originated. Chances are good you just need to pop the cap off the drain pump and clean it out. Here is a vid that explains the procedure.
http://www.youtube.com/watch?v=iLftnaruKp8
Jan 21, 2013 | Maytag EPIC MFW9700S Front Load Washer
My Epic Z front load is leaking water . It looks like the gray rubber on the door is the cause. The machine is only 18 months old
In the front on the bottom of the gray seal is two drain holes, make sure there is not an obstruction in these drain holes such as a small sock .
May 21, 2011 | Maytag EPIC MFW9700S Front Load Washer
Washer leaking water around front door
Check the seal around the front load door. It's possible there could be a crack along it.
Feb 28, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Maytag Epic front load washer is dripping a small amount of water from the water entry point in the tub. Is this normal after washing a load of clothes? I have not noticed it before.
I do not think this is normal. This may be a sign that your water fill valve is going bad. I would recommend shutting off your water supply valves when not in use and do not leave unattended when in use in case it gets worse. I would get repaired as soon as possible.
Mar 19, 2010 | Maytag EPIC MFW9700S Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer has a water leak coming from the bottom!
usually this is the front seal around the door they do crack with age. you will have to pull the front of the washer off to change it any appliance parts co. should be able to get you one
May 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
2,397 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
