Question about Oki Electric Industry B431dn Printer
B431dn Printer firmware update - Oki Electric Industry B431dn Printer
SP35 cards not printing more than one colour
Check to see if you have the current firmware installed on the printer. You can discover the version by going to Start > All Programs > Datacard Card Printers > Datacard Printer. Look at the bottom of the of the dialog box [Printer Toolbox] for the number following Printer Firmware Version. The number should be above version 24.49.
Datacard released a a new ribbon model that includes a new RFID chip. Printers with the older firmware will not recognize the new chip and thus think the ribbon is black only.
  1. Update the firmware by going to the Datacard website and use the search function in the top right corner of the website.
  2. Enter the search string "SP35 Firmware" one of the top links will point you the the Driver and Support page.
  3. Once the page loads, scroll down to the firmware subsection.
  4. Click on the "Begin your Go Green firmware upgrade now" link.
  5. Enter the contact info and click submit.
  6. Click download link once page loads.
  7. Open or Run download.
    1. This program will install software on the computer to update printer to new version of firmware. After the firmware is updated the program will ask if you would like to uninstall at end.
  8. A new dialog window will display Card printer Firmware Update.
  9. Select from drop down the Datacard printer that requires a firmware update.
  10. The dialog box will either display the update firmware version that can be flashed or indicate the "printer contains the latest firmware."
  11. If a update is possible click the Update button in the bottom left corner of the dialog window.
    1. Do Not Disconnect the power during the flash process.
    2. The printer will make beeps while the printer is flashing, this is normal.
  12. Wait till you hear the printer perform it's start-up sequence and you see a dialog on screen for success.
  13. Open Printer toolbox as mentioned above and review the firmware version number in the bottom left corner. Notice it should be a number greater than 24.49.
  14. Click on the Supplies tab in the printer toolbox dialog window and review the ribbon type.
Apr 10, 2014 | Datacard SP35 Printer
Oki b431 service 134
It may be necessary to replace the LED head. Part number 44317201
Apr 03, 2014 | Oki Electric Industry B431dn Printer
Error message
If looking into the paper feed there is no visible jamb, check the outside of the printer elsewhere. There is usually an access panel that comes off to manually remove any caught paper from behind where your paper loads to copy.
Sep 19, 2013 | Oki Electric Industry B431dn Printer
Ned drive printer oki B431dn
You should be able to find what you need here. Select your operating system on that computer and click on the right file.
Apr 11, 2011 | Computers & Internet
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
How do I solve a 49.2f01 error and what could be the problem?
Error 49.2f01 indicated corrupt Firmware, which are Programming instructions that are stored in a read-only memory unit inside the printer and it can be fixed by downloading and the updating the firmware through the following process:
Update the printer firmware by loading the new firmware file from the computer. You can find new
firmware files for your printer at www.hp.com. Click here to download latest firmware and firmware updating utility.
1. Open the HP Printer Utility.
2. In the Configuration Settings list, select Firmware Update.
3. Click Choose, navigate to the firmware file that you want to upload, and then click OK.
4. Click Upload to load the firmware file.
Please refer to PRODUCT USER MANUAL (Page-29) before proceeding.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | HP LaserJet 4700 Printer
Help !!!! Firmware updates scx 4521f
FLASH UPGRADE There are methods to update the Flash. (1) Local Machine • RCP (Remote Control Panel) mode This method is for Parallel Port or USB Port. Connect the PC and activate the RCP (Remote Control Panel) to upgrade the Firmware. < Method > How to Update Firmware using RCP 1. Connect PC and Printer with a Parallel Cable or a USB Cable. 2. Run the RCP utility and select Firmware Update. 3. Search for the Firmware file to be used to update the set using the Browse Icon. 4. Click the Update icon. The firmware file is transmitted to the Printer automatically and the printer is initialized when the download completes. 5. Click the Refresh icon and check that the updated version numbers are displayed.
Aug 19, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Printer
Try updating the printer's firmware. I had the same problem with my Windows XP machine and my Kodak 5500 AiO Printer. Then, I went to Kodak's website, looked for my printer, and downloaded their firmware update. The only curious thing is that when I ran the software to update the printer, it said the firmware version of the update was the same as the firmware version the printer already had. I went ahead and updated anyway, and now it works!
Just be careful when updating the firmware on your printer, follow Kodak's intructions.
Sep 08, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Oki Electric Industry B431dn Printer Logo
647 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Victorman
Victorman
Tony
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
