Question about Xerox DocuColor 240 242 250 252 260 ROS Assembly C, K 062K15037
I have fadded line on my cyan tone prints - Xerox DocuColor 240 242 250 252 260 ROS Assembly C, K 062K15037
    Habit-Forming:
  • 24 Answers
Open cyne devloper module and clean devloper by teaspoon
Posted on Dec 10, 2015
Why too much yellow and red no greens or blues ?
Inkjet printers use additive pigments. CMYK, Cyan, Magenta, Yellow and Black. It sounds like you're not getting any Cyan ink to the paper. Either your printer is out of Cyan ink, or your Cyan print head is clogged.
Go into your printer's Properties and run a Nozzle Check. It will print a series of lines with each color. There will probably be a big empty space where it tried and failed to print Cyan. You can try cleaning the print heads, but if you're getting NO Cyan that is unlikely to work.
If you're lucky, your printer is one of the ones that the print heads are built into the ink cartridge so replacing the cartridge will resolve the problem. If you're not, you might need to get it serviced (or probably more cost effective, buy a new printer).
Apr 30, 2014 | Epson Stylus CX5700F All-In-One InkJet...
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
I noticed while printing today that the colours were in two tones. When I did a Nozzle Check Pattern the Cyan line was divided into two tones. I cleaned and then deep cleaned but still the pattern rem
You have blocked printhead nozzles. If several deep cleaning cycles cannot fix the problem then a new printhead is required.
NOTE printheads are expensive and in most cases purchasing a new printer will be the most cost effective solution.
Apr 03, 2012 | Canon PIXMA iP4300 InkJet Photo Printer
I just replaced the cyan cartridge and I get 4 blue lines that print where they should not be. If I print a blue picture - those line tend to be a lighter blue. I have taken the cartridge out and replaced...
Obviously you need to return the Cyan cartridge to where you got it. It is bad. Is it OEM Samsung or is it remanufactured. If it is remanufactured then it will usually say "for use in" or "remanufactured" somewhere on the box.
Either way it sounds like you need a replacement cartridge under warranty.
Sep 14, 2010 | Samsung CLP-600N Laser Printer
Recently replaced the magenta cartridge and it was printing everything in pink tones (but the magenta still registers full). Just replaced light cyan cartridge and now its not printing full lines of text...
I'm not really sure, but if I were you, Id work with all the cartridges. Moisten a lintless soft paper or tissue and gently wipe printhead of each cartridge. Be sure you 'seat" them carefully and securely. I think one or more cartridges is empty OR dry. See if this helps a bit.
Aug 13, 2010 | Epson Stylus RX580 InkJet Photo Printer
Color on monitor is great but when printed has purple tone to them.
try printer a nozzle check from your printer.. most probably one of the color is not coming out.. the print nozzle check should have all the colors... Yellow , Megenta, Cyan and Black...
May 20, 2010 | Office Equipment & Supplies
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Xerox DocuColor 240 242 250 252 260 ROS Assembly C, K 062K15037 Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
