Question about Intel DG31PR Motherboard
Intel DG31PR Motherboard not booting
Processor: Intel Core 2 Duo 2.66GHz (E7300 - 45nm)
Motherboard: Intel DG31PR
RAM: Transcend 2GB (800 Bus) X 2 = Total 4GB
HDD: 320GB Samsung
This pc was working great. I bought 2GB A-data (800bus) DDR-2 RAM first. Then I decided to make it 4GB, Then I returned A-data RAM to the store and bougth two 2GB Transcend 800bus DDR-2 RAM. After attaching those RAMs the PC isn't booting. Motherboard's green (5v SB_PWR) light is on but got no response when I press the power botton. I tested the power switch, Itz ok. I re-assembled everything but still having same problem. Also CPU and chasis fans are remaining off. I tried attaching single ram and tested both slot but no change. Pls help. Just wondering can it be a electro-static discharge problem??? Thanks in advance.
  • shovon_net Jan 29, 2009
    Well, problem is now solved. I took a 1GB DDR-2 800bus (Twinmos) RAM from my office, then I attached that RAM and pressed power button, pc just turned on :-D... It was a great relief... after that I removed that RAM and attached my 2GB Transcend RAM, found itz working too... then I attached another 2GB RAM and it worked too... now entire 4GB RAM and everything working great.... my god!!!! Don't know what happened and how it solved... anyone has any idea about this??????? Thanks "wjcb" for your kind reply.
  • 3 Answers
You could try reseting the Bios settings using the jumper of the motherboard after installing the new Rams. Anyways ,its working, so don't do that now :P .
"If some thing is working, don't try to fix it" :) .
Posted on Jan 31, 2009
  • 50 Answers
Since your pc is just working great before you installed those rams, you just need to reset your processor, to do it: gently pull out the processor from your motherboard, be sure to do it carefully so that no further damage can be made into your motherboard then clean the copper side of your processor with a pencil eraser and apply a small amount of silicon grease or silicon paste of your processor then insert it in the processor socket and after install the heatsink. Hope this works
Good luck
Posted on Jan 28, 2009
I want know intel d 945gcr supports quied core processor or core 2 duo processor?
Support for the following:
Intel Core 2 Duo processor in an LGA775 socket with a 800 MHz system bus
Intel Pentium D processor in an LGA775 socket with an 800 or 533 MHz system bus
Intel Pentium 4 processor in an LGA775 socket with an 800 or 533 MHz system bus
Intel Celeron D processor in an LGA775 socket with a 533 MHz system bus
Aug 14, 2014 | Computers & Internet
Your question about DG31PR Motherboard has been posted. i have dg31pr M/b,core 2 duo processor,i have 2x2gb ram 667,but long beep sound are coming from,and remove one memory system is working,and put...
Sounds like your second stick of ram is bad or incompatible. I look for a matching stick of ram to the one you have that is working.
Hope this helps
Jan 25, 2012 | Intel DG31PR Motherboard
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dg31pr
Jul 08, 2011 | Intel DG31PR Motherboard
I want to know that did intel d945gcr supports core 2 duo processor...............plz
This mother board will work if we have a compatible processor like Intel Core2 Duo, Intel Pentium D, Intel Pentium 4.But the processor should be greater than 2.99Ghz if the processor is less than this then it will to work.Dual core processor means there will be two processors working
The detailed specifications of the new Intel D945GCCR Motherboard are:
  • Form Factor:MicroATX
  • Processor:Intel Core 2 Duo, Intel Pentium D, Intel Pentium 4 and Celeron D processors in the LGA775 package
  • Supported System Bus:800 MHz / 533MHz
  • Chipset:Intel 945GC Express Chipset with ICH
  • Supports Hyper-Threading Technology
  • Graphics:Intel Graphics Media Accelerator 950
  • Graphics Connector:One PCI Express* x16 graphics connector
  • Memory Support:Dual-channel DDR2 533 / 400 MHz, 2 DIMM slots (2GB Max)
  • Expansion Slots:Two PCI connectors
  • One PCI Express* x1 connector
  • Audio:Intel High Definition Audio with 5.1 Surround Sound
  • USB Ports:Eight Hi-Speed USB 2.0 ports (4 back / 4 front)
  • Storage One IDE (ATA 100/66/33)
  • Four Serial ATA ports (3.0 Gb/s)
  • On-Board LAN:Intel PRO 10/100 Network connection
  • Warranty:3 year limited warranty
Hope that solve your problem!
Thanks for using Fixya!
Dec 15, 2010 | Intel D945GCCR Motherboard
Do i have to face any heating problems with the mentioned config?
If you are NOT going to overclock the CPU and memory, it should work easy.
New C2D processors are quite cool.
Also you shoult pay attention to a good Power supply, and maybe enough big case with place for front and rear extra fans,
If you face heating problems later, you may put those two fans.
Regards.
Mar 27, 2009 | Intel DG31PR Motherboard
A disk read error has occured press CTRL-ALT-DELETE to restart.
check power chord or port of hard drive if u dont find any prob. pleace re insert power cord with card board packing. definetly u solve the problem.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Product comparison
deal 2 is definatly better, go for it
Oct 28, 2008 | Computers & Internet
Problem with DG31PR while loading windows 2003 server with 4gb ram
You MUST run a 64 BIT if you want to run anything more than 3 Gb of ram ( such as windows xp 64 BIT , Vista 64 BIT , or even winows 2008 server 64 BIT ) Windows 2003 does NOT support 64 BIT ....
Jul 29, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
694 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
