Question about Brother HL-4040CN Laser Printer
Brother HL-4040CN Laser Printer does not feed the paper and stops. I open the paper drawer and the paper will be just above the drawer and I will push back down and close the drawer. Sometimes it will print, but sometimes I have to open and close many times and then it will work.
I have brother 4040cn printer but its not working any more its showing me no paper load paper in multi purpose tary.
so fi any one there for help me please help me .
thank you
Posted on Jan 10, 2010
My Brother HL 4040cn showes a Jam MP Tray. There are no papers jambed but it will not reset.
Hi James,
Remove the paper from the MP tray.
Remove any jammed paper from in and around the MP tray.
Fan the paper stack, and then put it back in the MP tray.
When loading paper in the MP tray, make sure that the paper stays under the maximum paper height guides (1) on both sides of the tray.
Press Black (Mono) Start or Color (Colour) Start to resume printing.
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother HL-4040CN Laser Printer
Jam Tray 1...I see no paper anywhere...What do I do?
Check that the paper feed and alignment mechanisms are free in and leading out of the tray. Check very carefully that there is not even the smallest scrap of paper stuck somehwere or hanging up the works. It doesn't take much to make the printer report an error.
Jan 25, 2011 | Brother HL-4040CN Laser Printer
THE PRINTER IS INDICATING A PAPER JAM, THERE IS NO SIGN OF PAPER, THE DRAWERS ARE ALL CLOSED TIGHT
Paper light flashing could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 05, 2010 | Brother HL-2040 Laser Printer
Brother 2040 printer blinking paper light - I open all of the drawers, took out and put the cartridge back in, played with the paper wheels and it won't stop blinking!
Hello ,
This is due to your computer software selecting the manual feed instead of tray one usually because the software program decides that the paper size is not the standard letter size, such as envelopes, and has to go through the manual feed.
If you are having trouble finding the manual feed, it is found just above the paper tray, usually on the front panel of the printer.
If you are trying to print a letter sized document yet the printer still asks for the paper to be inserted into the manual feed, then one of the settings in the software you are using needs to be changed.
For most windows based applications, you can find a “page setup” menu; in this menu, there is a section that specifies the tray being used to print from.
Make sure the setting in page setup is set to “tray 1” and not “manual”
Thank you,
Mar 29, 2010 | Brother HL-2040 Laser Printer
My brother hl 4040cn is printing fine, except there is a blank vertical line in the middle of the page. what is this?
Usually just toner dust on the laser lens, you remove the toner and drum and look on top inside for a window about 1/2 inch wide. You wipe that window with a dry cloth, and also check for paper scraps inside or on the drum assembly.
Nov 18, 2009 | Brother HL-4040CN Laser Printer
Brother HL-4040CN Fuser Cover
Click this link below;
http://www.uninetimaging.com/newsletter/Brother_HL_4040_TN_115_Reman_eng.pdf
Sep 08, 2009 | Brother HL-4040CN Laser Printer
Installing paper
The printer loads paper from the installed paper tray or the manual feed slot.
For ordinary tasks, though, you would use the paper tray. This is located in the bottom front of the printer and looks as a kind of drawer. Pull it open to feed the paper.
You can download the User's Manual for your printer from Brother:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
I am assuming you have a printer
Aug 26, 2009 | Office Equipment & Supplies
Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
Dec 16, 2008 | Brother HL-4040CN Laser Printer
Printing dots on Brother HL 4040CN
do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
Apr 01, 2008 | Brother HL 1440 Laser Printer
Brother HL-4040CN Laser Printer Logo
639 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
