My ProlineTV vi a digibox has stopped working
In the middle of a programme my auntie's TV said there was a signal error, a short while later the programme resumed. Now when she turns on her TV she cannot get anything. i have checked her digibox and it appears to be working (greenlight) but I cannot access a menu, The screen on AV2 displays a dialogue box 180 xxXpanded TV Data Service. Can anyone offer a solution as to how I sort this for my 86 year old auntie.
dodgecharger
  • 254 Answers
SOURCE: While playing back a recorded programme picture is lost and AV2 appears on the tv, sound can be heard on recorded programme playing back.
Does it do so on all tapes? It sounds like you are experiencing a tracking or tape path problem. You might try taking the top cover off, then cleaning the video head. Info is available on the 'net on how to do this. If problem remains, play a tape and see it is wandering up/down across video head. See if any of the tape guides are broken or bent, causing tape wandering. you may also have a problem in the electronics, perhaps in the servo circuitry, which has to do with careful control of tape speed, video head rotational speed, and certain other parameters. If electronics are bad, then VCR is likely a tosser, unless it is a high $ rig. Most electronics are disposable these days, unfortunately.
Posted on Mar 08, 2007
SOURCE: Display
press and hold down the i button on the remote and the screen program number will disappear
Posted on May 14, 2007
  • 4 Answers
SOURCE: Samsung LE26R73BDX 26INCH - LOSS OF DIGITAL SERVICE
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
  • 13433 Answers
SOURCE: Turn off On Screen Display?
Hey,
unless you have such a option in the on screen menus, please go over all of them, then no, althought it should atleast my monitors do goto power safe mode ones theres no signal.
Thanks,
Ekse
Posted on Sep 06, 2008
SOURCE: Bose Lifestyle V20 Error 180
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Posted on Mar 10, 2009
I have a AEG Favorit 65011 VI dishwasher which stops in the middle of a programm an shows error ,60 that is not mentioned in the Users Manual. Can you please help me?
Fault in heating phase. Could be:
Heating element, wiring between heating element and power board,
power board (usually relay). Sometimes can help to resoldering (cold solder joint) or replaced relay on power board.
Dado
Mar 10, 2015 | AEG Dishwashers
Why won't my Goodmans digtial box remote change channels or volume on the TV?
Think about it. The digibox remote should only change its own channels, not the TV ones. Otherwise the TV would never be on the correct channel to see the digibox signal.
As for the volume, unless the Goodmans remote is programmable to emulate the TV volume, then it will just change its own volume. The result is the same. The TV gets louder or quieter.
Sep 03, 2014 | Televison & Video
Why is the Goodmans digital box remote not changing the channels or volume on My Daewoo TV?
How do i get signal on my scott tv?
if not digital, no signals now all stopped. you need a digibox to pick up digital signals now. Not sure if crt has setup for digital. sorry.
Jun 29, 2014 | Televison & Video
Wil my tv work with out remote
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.connecting the speaker wires of an RCA TV to an amplifier: The signal that is fed to the speakers is not designed to be fed to the line-level inputs of your amplifier. You'd need some kind of conversion and I can't tell you exactly what that would be.
Get some double-screened satellite cable and fit a female TV plug to it (or a male plug with an adapter). Connect it to RF Output 2 at the rear of your Digibox. Fit a TV plug to the other end and plug it into your TV.
Temporarily disconnect the aerial feed from the Digibox aerial socket. Switch the Digibox on to get a picture on your main TV. The Sky Digibox normally sends its signal out on UHF channel 68 so go to the second TV and tune it to 68 (or tune it till it finds the Sky picture).
Now plug the aerial cable back into the Digibox. If there is now interference on the Sky picture on the second TV (or on the terrestrial channels) your Sky signal on 68 is causing interference. Press [services] 401 [select]* and set the RF output to a different UHF channel number. You need to connect it via a Scart lead on your main TV in order to see the menu.
*In the new EPG (April 2009) it's [services] 001 [select]
Try each RF output channel number in turn (21 - 69) and retune the second TV until you get clean pictures on the terrestrial channels and the Sky channel. Also check the picture from the VCR (if connected).
This is just a brief overview. If you need a real in-depth explanation you should read the "Piping TV Around the House" Ebook by satcure.
Nov 22, 2011 | AOMNI Corporation Televison & Video
How do i reset my lc26dv20 u back to factory so that my inputs will work
Just unplug,replug the tv back about an hour later.The tv now,it is resetting back to the factory setting.If ur tv still have the same problems,ur tv Tuner signal board itself is the causes and the problems,must be change the tv Tuner signal board it self,if u want the tv to be fix.
Apr 27, 2011 | Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
Can the LG 990W VHS VCR receive digital TV signal
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
Dec 05, 2010 | LG MG64 VHS VCR
How do you fit a two way booster to a digibox and a tv?
Hello. When you boost the signal to the digibox it will also boost it to the tv. So just install it in the incoming line before the digibox. 10412402.jpg
Jan 25, 2010 | Televison & Video
Samsung LE R88 BD LCD TV / digibox problem
Hi.
Its a long shot but try this,
It can cause problems when you switch set to & from stand bye.
Check that you are viewing a digital TV channel
Enter the menu and navigate to:
Setup > System > Software Upgrade > Standby Mode upgrade
Change the setting to Off.
I cant gteee that this will sort your problem out so post here if it doesnt & I will check samsung data base.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
