Question about Jenn-Air JMC7000 Microwave Oven
Jenn Air Microwave M169W will run but not heat
The Jenn Air microwave is over 10 yrs. old. The model number is M169W. The unit will still run when programmed, the light comes, and the turntable works. The food does not heat up, can this be the magnetron? How do I discharge the capacitor?
  • Jenn-Air Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
zcvzcv
Posted on Sep 30, 2010
I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
Sep 29, 2014 | Jenn-Air Microwave Ovens
Heating problems Jenn-air microwave - jmv8000bds - it heats while unused for a while but to warm more than the first item is not working - what is broke? jeffrey40@yahoo.com
First, check to make sure that the air vents are clear. Secondly, is the cooling fan running? If these are OK, (how old is this unit?) it's probably the magnetron is old and weak....... Put in a container with 2 quarts of cold water and run it for 10 minutes. It should boil water after about 4 or 5 minutes and keep boiling it for the remainder of the timer preset. If not, the magnetron is losing power.
Sep 20, 2013 | Jenn-Air JMC8130DD Microwave Oven
It is running with funny noise and not heating?? It's about 20 years old. What suggestions do you have. It is an over the Jen Air range unit. Has the fan, etc...
heatman101 ][
Jul 17, 2011 | Jenn-Air JMV8196 Microwave Oven
Hi, I have a Jenn Air microwave oven Model M169W that a repair shop has not been able to repair. It quits heating after 7 or 8 times of use.What is the problem? A new control board and magnatron have been...
The pros cant fix it? Your expectation is high, evidently!
I would presume they checked the cap output and the door switches. Can you verify they did these two very important checks?
If you are unsure, you could check the door interlock safety switches yourself.
Beyond that, I am frankly afraid of getting a no thumbs up rating on this answer so I will not go any further.
Oct 16, 2009 | Microwave Ovens
MIcrowave quit on February 15, 2008. I can't get parts to repair
seems like you have to replace the control/touch panel module of the oven.
Mar 21, 2009 | Jenn-Air JMC7000 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
Dec 19, 2008 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
574 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
