Question about Amana Refrigerators
Fan isn't running
    Genius:
  • 1,669 Answers
Check for power to the fan, check to see that there is no fuse with the fan that may be blown, bypass refrigerator power and test the fan with jumpers.
Posted on Jan 24, 2013
50010xffffec75
dude- all the wholes in your pc closed off??? if so then your fan what is it barring or magnetic? if it is baring then you will need to replace... my guess it is.. if it were magnetic it would just stop PERIOD...the fan isn\'t spinning enough ( high enough rpm\'s) to keep a constant flow at the rate in which the CPU needs or heat sink needs....you should have a diags in or with in your bios....run those it\'ll tell you what it is at or what it should be at... you can make decision then.... if your fan isn\'t running then just replace fan. If fan is running and your diags isn\'t loaded or doesnt have the utility ...you will need to swapp the fan from a good working PC or buy a new one.. if you STILL have issue thn your problem lays with in the power supply... it is either your MAIN power supply or it is your motherboard (12v) then you will need another mother board. hope this helps!!!!
P.S. is your fan clean heat sink clean?????
May 14, 2014 | HP Computers & Internet
Relays click when interior fan is on
Often the click which can be heard when the A.C. kicks in is the clutch on the A.C. compressor. Be sure that it isn't just this sound which you are hearing.
Also check the operation of the idle control valve which is supposed to raise the engine revs to compensate for heavy power drain. If this isn't working correctly, then this would explain the lights dimming under low revs.
Nov 16, 2012 | 1998 Ford Escort
Location of thermostatic switch 1993 Buick Regal 3.8 motor fan motors don't run
The fans are controlled by the ECM and it uses the ECT sensor for temperature sensing, so if the check engine light isn't on the sensor is not the problem. You need to have an active test run on the fan system to see what code is returned. Have you tried powering up the fans at the relay?
Oct 26, 2012 | 1993 Buick Regal
Condensor fan slow starting
if the fan isn't running correctly change it out,you can remove the bottom back panel and stick a house fan back there for now so your compressor doesn't cook but change that fan motor out if it's bad.
Aug 10, 2012 | Amana Refrigerators
RS265LABP freezer works but fridge doesn't.
if the evap fan motor isn't running then most likely this is you rproblem
Nov 25, 2011 | Samsung RS265LABP Side by Side...
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
The outside unit has power going to it but isn't
maybe it has tripped off on high pressure, as you have have said the fan is not turning so will cause high pressure. now assuming the problem is the fan is not running than check the condition of the condensator /capacitor for the fan motor. if the motors winding is still good replace the capacitor and try it ON.
Aug 23, 2011 | Goodman CKL62AR61 Air Conditioner
I have a kenmore refrigerator side by side. my problem is that my freezer is not freezing the top where the ice is. everything was melting and defrosting inside the freezer except the lower part. i need to...
If lower section of the freezer is working but upper not the most likely problem is going be the fan in the freezer isn't running. Do you hear that fan running? if fan is not running it also wont circulate air into the fresh food(ref) compartment. If it isn't running you can possibly jump start it by removing back and flinging the fan blade with your finger to get it going till you can get replacement
Good luck,i hope this helps
Gene
Aug 01, 2011 | Refrigerators
My 2000 galant is having high engine temp when i stock in traffic,but it is in normal range when im running. i change already the thermostat,rad cap and hoses, but nothing changes. what would be possible...
Sounds like the radiator fan isn't coming on. You don't need the fan on when you're moving, cause air is blowing into the radiator, but sitting still you need the fan or it'll overheat. This makes me think the fan isn't coming on.
Jun 13, 2011 | 2000 Mitsubishi Galant
Refrigerators Logo
44 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
