Question about Vizio VA26L 26 in. LCD HDTV
Vizio VA26LHDTV10T - No power, when first plugged in the Vizio logo lights up for a few seconds then goes out
TV was working fine for a couple years, all of a sudden it will not turn on. If I unplug it and plug it back in, the Vizio logo lights up for a second or two then goes dark. Tried the 'unplug and hold in power button' thing, no improvement. Looked at the caps on the power supply, no indication of bulging or leaking, although I know that doesn't necessarily mean they are all good. Any tips to start troubleshooting this would be appreciated.
3 Suggested Answers
SuperTech-11
  • 1591 Answers
SOURCE: i have a 37" hdtv
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Jun 20, 2011
SOURCE: My wife was messing around with our 1056B01-L
Have you had any luck? It just happened to me now!
Posted on Jul 04, 2011
How do I fix a vizio e320vp tv that turns on and then back off after about 20 seconds
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 18, 2015 | Vizio E320VP 32" LCD TV
My Vizio E422VL was working fine. I moved it to another room and it continued to work fine. A few hours later the TV will not power up, no lighted Vizio logo on the front. The TV does have power becau
You may have a power board issue. It may have simply blown the internal fuse also. Couldn't hurt to check it? Moving it may have possibly jostled it? Especially if you get no 'Power light blibs' on and offs when you plug it in. Usually these flat panels have some power light diagnostics. Like 3 on/offs then full off says power supply.
Dec 07, 2014 | Vizio Televison & Video
My vizio tv just has the vizio light on when i plug it in it wont turn on
Sounds like a problem in the power supply. Possible bad capacitors if you can have it checked out.
Apr 22, 2013 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
When I plug a brand new HDMI cord into my Vizio VA26LHDTV10T it says
Have you used the input display ie usb freeveiw hdmi avi ect because your tv will have a input display ?
Sep 07, 2012 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
May 12, 2012 | Vizio M261VP 26" LCD TV
Vizio VA26L 26 in. LCD HDTV Logo
381 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
