TV and computer monitors have slightly different aspect ratios. You need to the configure the PC display settings. Check also if there is a panasonic display driver for your TV.
I would say that is most likley the motherboard not the power supply and this is a pretty big job you would have to take the laptop apart if the laptop is under warrenty I would use it otherwise you would most likley be better off getting another computer unless you are very good at taking computers apart. You can go to HP website support and get repair manual and it will tell you how to take apart.
Try running through the Sound setup wizard in windows. It should dynamically adjust the speaker setup providing you answer the questions correctly. # of speakers, type of sound etc.
G/L
1. On restart, press F8. This should bring you to a screen with various boot options.
2. Select "Last known good configuration". Windows then may load correctly.
3. If this doesn;t work, try the same thing. This time select "boot in Safe Mode". If Windows now loads in Safe Mode you should be able to restart and Windows may load correctly after this.
4. If these two both fail, you may have to repair Windows...
since your computer didnt recognize your monitor just add it manually ...if its an hp lcd screen hit the button above the power button on the monitor and it will auto adjust itself..if it still dont work go under control panel to monitors and add it.
i hv purchsed HP Pavilion tx1000 notebook pc. it was getinig vy heat due to this region pc was getting shut down. i hv given it to my near by service center. but still it is not working properly. its web cam as (HP pavilion Webcam Driver for Vista v061.001.0005- chicony) driver is also not loaded properly. when opens with net it gives error.
pls help me wht to do?
