Question about AOC L32W861 32 in. LCD TV
How do I adjust my screen size
My screen size recently went from a 32" down to a 19". I cannot locate the original remote and am currently using a universal remote. How do I bring the screen back to the original 32" size.
  • Niles Yoho Jan 24, 2013
    video menu where to fix this
    Sorry, the video menu did not help us to fix this. There is a settings button that we were unable to open
  • AOC Master
  • 3,904 Answers
You can do this manually throught he menu and using the volume/channel buttons to toggle to the choices. Go to the video menu and in there you will be able to adjust the display size.
Posted on Jan 24, 2013
What size of screws/bolts do I need to mount the base to the TV?
It uses metric machine screws. You may have to spend some time at your local "big box" store searching for the right hardware, BUT length is important from a safety perspective. Insert a toothpick in one of the holes and mark where it is flush at the top. Take your toothpick to the store and match length with the M4, M6, etc. screws you will be sorting through.
A large screen TV such as yours requires two people to place it screen down on a soft surface such as a blanket for hardware installation. Be sure to tighten the screws firmly. Enlist the same two people (or designated alternates) to lift the TV and place it where it should be located.
Sep 05, 2015 | Westinghouse Televison & Video
32" scene picture is 19" rest the scene is black
As per the operator manual in the case of the picture not showing up correctly, begin by pressing the "PICTURE SIZE" button several times to cycle through the various size options (sounds like you have tried this though). Next, press the power button first
to see if it fixes the issue... if not, then press this sequence of buttoms on the remote control (6 buttons in this sequence):
"SLEEP", "PICTURE SIZE", "[right arrow]", "[up arrow]", "[down arrow]", "[pwr button]". This restores the default screen size settings.
I am not sure how you are using your monitor (TV, HDMI, Composite, PC Monitor, etc.. ). That would be very helpful.
If this does not resolve the issue, I would suggest downloading the service manual from this link to work through the advanced troubleshooting flowchart... They point to a reinitialization of the basic functions (reset the TV to factory defaults) through the initialization process. I have worked on a number of this model, and have almost always found it is settings which have been inadvertantly mis-adjusted while tweaking preferences or the last settings of the operation since it will always go back to the last way it was setup when you power it up (no matter what modality was in use last time.. eg. 480i in PC or DVD operation changed to HDTV next time). Remember the HD 16:9 screen is nearly twice as long as the old 4:3 screens, as well as having nearly twice the vertical pixels... Thisis what it sounds like in your case with the 19" screen to me.. Let me know if this helps...
Service Manual:
http://www.buyphilipsparts.com/shop/research_new/MAG/sm/32ME303V_F7.pdf
Operator Manual:
http://www.emersonaudiovideo.com/product/product.php?id=649
Oct 10, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
Sony kv-32hs420 screen mode doesnt work
Display ratio usually is a setup choice but bear in mind that old movies and old TV programs will display in 4:3 ratio. Remotes usually have no control over screen size.
Dec 28, 2013 | Sony FD Trinitron WEGA KV-32HS420 32" TV
43 inch plasma samsung tv with abnormal picture size .i want to adjust but i dont have serivce menu codes please help.
Using The Remote Control Your remote control will have a button on it to quickly adjust the picture size.
  1. Press the P.SIZE button.
  1. The current picture size will be displayed on the screen.
  1. Press the P.SIZE button repeatedly until the desired picture size is selected.
  2. Important: Some picture sizes are only available with certain resolutions or certain inputs.
Using The On-Screen Menu
  1. Press the MENU button. [The Main Menu appears]
  1. The Picture portion of the Main Menu will be selected by default, if it is not selected use the directional arrows to select the Picture portion.
  1. Use the directional arrows to select Screen Adjustments, and then press ENTER.
  1. Picture Size will be selected by default if not use the directional arrows to select Picture Size, and then press ENTER.
  2. Note: The current picture size selection will be displayed to the right.
  1. Use the directional arrows to select the desired picture size, and then press ENTER.
Nov 12, 2013 | Cell Phones
Lost remote for emerson lc320em8 32 in. lcd tv, how can i adjust the screen mode to get full screen without the remote?
Hello
It is immpossible to set its screen resolution or screen size, without it remote control. Try to get one original remote control, from the authorised service center for Emerson at your town, or buy a universal remote control, which have setup codes for Emerson TV with it. OK.
Feb 09, 2012 | Emerson LC320EM8 32 in. LCD TV
I lost my remote, and the picture is smaller than the actual screen by about 2-3- inches on all sides. how do i enlarge the picture to fit the screen?
This function u can't do it without the tv original remote.Try website like Remotes.com to buy the tv original remote.Than used one of those buttons on the tv remote like View Modes,Picture Sizes,Aspect Ratio,Zooming to do the adjustment for tv screen pictures sizes.
Jun 23, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
Black box on bottom of screen of Sharp tv
Change the "picture size"... the remote has a button: [p.size]
Sep 07, 2009 | Televison & Video
The viewable area is bigger than the screen. I
You probably need to go into the control panel and change the resolution for your display
Mar 12, 2009 | ViewSonic VP920b 19" LCD Monitor
AOC L32W861 32 in. LCD TV Logo
99 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Jayesh Panchal
Jayesh Panchal
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
