Question about General Electric WHDVH660H Front Load Washer
Have a GE front load adora model WHDVH626FWW - loud banging noises while spinning. I have checked the belt and it is fine. Drum is loose - how do I get the drum out to see why?
  • General Elec... Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 24, 2013
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 21 Answers
I need a drum spider, not the whole drum. GE will not sell seperate.
Sounds like a scam. Anyone no of a spider that will fit?
Posted on Jul 05, 2013
2 Suggested Answers
SOURCE: Front loading ge washer won't drain?
Similar problem fixed in less than 5 minutes. Here's a post that was very helpful. http://www.foobert.com/blog/2007/04/02/ge-adora-front-loading-washer-does-not-drain/
There's a trap located under the front panel (3 screws) I undid the filter and pulled out 21 coins, 2 buttons, a 'letter h', zipper parts, a broach, and a whole lot of lint.
My wife said that the unit never got the clothes so dry afterwords, she said the almost didnt need to throw the clothes in the dryer.
NOTE: Have a ton of towels ready, and if you can fit a bucket or dish under the filter, go slow and steady. I opened it up and had several gallons all over the floor!
Posted on Jun 04, 2009
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Noise during spin cycle
what noise is it making, it may just be off balanced
Jan 17, 2012 | GE WSXH208A Front Load Washer
Wsher will not spin at end of cycle, tries to and stops. there was a loud bang in the previous load. drum will spin but tight. What to check kenomre 417-44142400
Hi stevensch693,
The loud bang you most likely heard is the capacitor of the motor, it has blown.
Open the washing machine up, look for the following component near the main motor:
You will need to replace this component. Be very carefull when disconnecting it, as it may still give you a nasty shock.
You can find these at any appliance spares shop or even hardware outlet. Note the number on it, if requesting a emplacement - even better, take it with when purchasing one.
Kind Regards
JEDMEEYER1
* If this solution helped you, please accept it
Jul 24, 2011 | Kenmore HE2 Plus Front Load Washer
I have a GE front loader washer model # WHDVH626FWW inner drum making loud thumping noise while washing and spinning
check your owners manual for warranty on inner tub and seal warranty parts may be covered in some cases but labor may not be....
Jan 27, 2011 | Washing Machines
The washer shakes uncontrollably during the spin cycle also a loud banging noise is heard during the spin cycle.....
If front load check the inner drum If it is loose at all you have a lot of problem . Very expensive.
Nov 17, 2010 | GE Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
Indesit wil103 makes LOUD banging noise on spin cycle
The two dampers that fix to the outer drum casing have plastic bushes that can fall out. Check the floor under the machine, They are easy to replace just click in place.
Jan 26, 2009 | Kenmore 43052 Front Load Washer
I have a GE front load washer model # whdvh626fww. it keeps making alot of noise when in the spin cycle and the belt keeps coming off. at first I thougt it was out of balance but that was not it . when I...
I have a different suggestion based on my washer's similar problem. If the black stuff is powdery and localized at the back of the unit, more than likely the culprit is the drum pulley itself is warped, causing the belt to chafe against the drum. The black powder is rubber residue from the scraping of belt on plastic. No need to replace unit. New belt and new pulley run about $70 each.
Jul 19, 2008 | GE Washing Machines
General Electric WHDVH660H Front Load Washer Logo
946 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
