Lg tromm front load dryer /not drying clothes and i do not hear the burner turn on.
  • Washing Mach... Master
  • 17,129 Answers
Check the element, it is possible there is no voltage from the control panel or there is fault in the connection or a burned element.
Click this link: Dryer
Posted on Jan 24, 2013
  • 4 Answers
SOURCE: lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Posted on Feb 23, 2009
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
SOURCE: LG WD-12331. Front load washer and dryer machine
since it is a washer-dryer, the lint trap is in line with the drain. you have to empty the drain basket. there's an access door on the bottom left, first take the little tube out and drain the remaining water, then open the large drain cap to the right and clean out the trap. once you're done put it all back together and it should work. you're supposed to do this every few months. It was too much for me to deal with so i ended up buying a separate dryer and just use the washer .
Posted on Aug 02, 2008
MNTECH
  • 1543 Answers
SOURCE: Lg Tromm washing machine drum will not turn
the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Mar 01, 2009
  • 5 Answers
SOURCE: clothes don't dry in my 4yr old whirlpool duet electronic dryer
If it is heating , check for a kinked or stopped up vent
Posted on Nov 18, 2009
My LG Tromm DLE5955W dryer has great airflow and heating but about 2 months after I bought it, it now takes 2 hours to dry a load of clothes. I have vaccumed it out and replaced the vent house already with...
You have a problem with the exhaust vent in the house walls. Try this. Disconnect the dryer vent hose from the back of the dryer and see how well it dries a load of laundry. If it comes out alright, then you know that the vent in the house is clogged and will need to be professionally cleaned out. Good luck
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Dryer not drying sufficiently
Clean out the vent air lines. If partially blocked or bent/kinked will cause this.
Mar 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Lg tromm front load dryer dlg5988w
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
