Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenmore portable compact top load washer model 110.49722992 when spinning the agitator come loose. I bought a new agitator, but I still got the problem with the new one. What is wrong?
  • Kenmore Master
  • 3,904 Answers
The nut that is on the top is coming loose. A lock washer and/or some lock tite should take care of this.
Posted on Jan 24, 2013
  • Beatriz Alegre Jan 24, 2013
    But this washer does not come with a nut like most washers. It has the tube& dispenser and the filter that fits inside the agitator without any nuts or screws.
Need to replace tub seal on a Kenmore compact washer model # 1102670091 is there a special tool for this
Here is a link to the wrench you will need to remove the agitator in your machine. Here is a video to show you how to replace it.
Happy Holidays!
Richard
Dec 09, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Washer will not spin or agitate. Pump works.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
First, see the following Whirlpool Kenmore installation and service manual for top load, direct drive washers.
If it drains and you can hear the motor trying to turn the transmission for the agitate mode, the obvious first answer is the Motor coupler. I'd replace it just to be sure.
If it's not the Coupler, the problem points to the transmission itself.
There are only two components of the gearcase that are used for both agitating and spinning.
One is the Agitator shaft which drives the agitator and holds the spin pinion that drives the clutch for spinning.
The other is the main "Bottom and pinion gearcase" itself.
Please see the following Whirlpool parts list for commercial top load direct drive washers although the consumer models use the same transmission parts.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Oct 24, 2009 | Kenmore Washing Machines
My Kenmore agitates while trying to spin??
sorry the repair is a new gearcase appx 230.00 plus labor in your area or buy a new washer ,,,,,
Aug 29, 2009 | Kenmore 24032\24036 Top Load Washer
Compact Kenmore top loadwasher does not spin
Clutch is failed. replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Washing Machines
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 2.1 cu. ft. Portable Washer - won't drain
Probably something caught inthe pump. Will have to remove pump and take obstruction out. Only other thing I can think of is the pump ran tight and would have to be replaced
Aug 15, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore portable compact topload washer model 110 49722992--won't spin!!
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Apr 03, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
111 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
