Question about Craftsman 4 Cycle Blower/Vac
Snowblower: fire from muffler
After about 10-15 min. of using the snowblower it belches fire from the muffler.
  • 979 Answers
Try changing the spark plug. You may be having some misfiring going on here. Is your fuel to oil mixture right?
Posted on Feb 03, 2009
Back firing out muffler stalls under load
Could be a bad exhaust valve seat, sticking exhaust valve and possibly a lean running carburetor which is causing the engine to stall out on loads.
Jan 03, 2014 | Briggs & Stratton Garden
Can't remove snowblower muffler rusted in place
Soak an old cloth in coca cola and wrap it then pour the rest of the coke over the area give it 10 - 20 minutes and tap it with a hammer or mallet
Jan 08, 2013 | Garden
White smoke belching out but will not start
white smoke is usually water, grey=oil dark grey=other fluids. with the belching and other symptoms i would be inclined to believe you have a blown head gasket.
Nov 15, 2011 | Cars & Trucks
Can't get fire on old snowblower TORO 8HP / 32"
te fly wheel is rusted over the magnets remove cover and sand the wheel at the magnets space should be about busnes card thick between the coil and magnets
Nov 03, 2009 | Garden
Mower belches out smoke and wont stay on. shoots out oil.
you need a new mower and im not trying to be funny but when oil comes out of the muffler that means the rings on the piston are shot
Aug 23, 2009 | Garden
Stalls out
This is usually caused by a stopped up muffler. Remove the muffler and see if this makes a difference. If it runs smoothly without the muffler then you must clean the "kook" out of it. This is done one of two ways. If you have a torch, even a portable handheld one, you can burn the muffler clean on the inside by removing it from the equipment, placing it on a burnproof surface and aiming the torch inside the muffler, letting it burn for 7 to 10 mins.
Also you can build a fire either outside if you live in an area this is allowed or in your fireplace if you have one, and just toss the muffler into the fire. This will remove the carbon buildup in the muffler, Just remember...LET THE MUFFLER COOL COMPLETELY ON IT'S OWN ...do NOT DIP IN WATER as this will warp it and it will no longer seal tightly to the engine. This should solve your problem.
Apr 24, 2009 | Garden
Smoke from snowblower muffler
Your gas to oil ratio is 32 to 1. Should cut down on smoke. replace sparkplug at same time.
Please rate this response and Good luck
Dec 29, 2008 | Toro Blowers Rake and Vac - Electric...
Craftsman 4 Cycle Blower/Vac Logo
492 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
