Question about Odyssey Lstand Laptop Stand
Assembling Odyssey Lstand
I just bought the stand from Guitar Center it what seemed like an un opened box but there appears to be some screws missing.....after attaching the side and top of the stand together with the bars and 4 caps that screw on the outside to hold them in place (2 on each side) Im stuck trying to figure out how I screw on the U Clamps to the bottom of the stand. there are 2 wing nuts....but those two would be used up on one U clamp....and no screws long enough. am I missing pairs of screws and 2 more wing nuts? Also there are a bunch of tiny black screws....but these I'm assuming are to screw the long flat bottom "feet" should you want to use those instead of the clamps. Im looking for a parts list or assembly instuctions if possible. Thanks.
Lol....after reading your problem and then posting mine I had an idea. I went to and found out that in order to hook up the U have to disconnect the table top attachment and connect the U Clamps to the short bases. You then dont need longer screws you use the little black screws that came with the stand. I went to Guitar Center after I did mine and confirmed that theirs was set up the same PARTY NOW !! This calls for a celebration GOOD LUCK AND TEAR THOSE PARTIES UP
Posted on Jun 14, 2009
Have a fender strat serial V019217
It is a US strat! Congrats! Guitar Info This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date
Fender: Corona Corona factory was opened in 1985, Corona California, with major guitar production starting in 1987. With the addition of a custom shop in 1987 the plant currently employs about 700 workers. Apart from general and Custom Shop Fender instruments and amplifiers, it also encompasses Guild acoustic & electric guitars.
May 19, 2014 | Fender Starcaster Strat Electric Guitar -...
I have IonAudio Discover Guitar. I am a Mac user, 10.6.8, MacPro 3GHz Xeon Dual Core with 6 GB RAM. The instructions say I should create an Aggregate MIDI Device under Audio MIDI Setup with the following...
Have you tried the guitar in another Mac/ PC? If it still doesn't appear, there may be a problem with the guitar electronics. If you bought it new, take it back to the shop/ send back to the vendor.
Just moved houses, and the amp puts out loud static when cable is plugged in. The house may not have grounded plugs, and I do not see a separate ground screw for attaching a stand-alone ground wire. What...
get a 3 way adapter,, plug your amp into the adapter, and secure the ground wire to the center screw in the receptical cover , or if it comes with a tab instead of a wire, secure that
May 30, 2011 | Fender Frontman 15r Combo Guitar Amplifier
Bought amp 1 year ago, three months ago, no sound, Guitar Center said call an authorized repair shop. I did'n't open it up to check fuse because i didn't want to void the warranty. The shop replaced the...
Possible that the output tubes that were replaced are drawing too much current, hence the popping sound (may be "motorboating", one common word to describe a similar sound)
This means the tubes need to be biased properly. You need to get it to someone who knows what they are doing, ie a good amp tech, not GC. The voltages here are dangerous.
Feb 25, 2011 | Marshall JVM410C 100 Watts Valve Guitar...
Okay i need to know how to get inside my amp to tighten up my input jack cause i cant play at all on my amp cause i cant get inside it i took off all the screws in the back and trying to get it off is a...
One can overtighten the input jack and "un-rivet" the jack. They are not made very well !!! OFTEN when they appear loose, they HAVE un-riveted the threaded sleeve from the metal inside the jack... that USUALLY requires REPLACEMENT of the jack itself.
The cabinet backs on a lot of these have to be PRIED out as the Tolex covering often makes them tight.
The amp portion is often retained by screws from the top and or sides AND even the two holding the handle on... there are many different configurations. Sometimes the amp comes out the front, sometimes the back. It is easy to shear off the speaker wires when removing some of them.
Dec 18, 2010 | Marshall 15 Watt Guitar Amp
Proline Piano Keyboard Stand Assembly Hi, I just bought a Proline piano stand for an electronic keyboard, and the first step on the assembly directions is to move the clutch to the middle position....
Normally on my stand like this you PULL the knob outward (not turn it) to disengage the pin from the plate with the holes in it... Works quite well and the stand is moree stable than many.
Nov 28, 2010 | Pro Line Proline Pl 400 Double X Braced...
Can you send me the instructions to assemble the Lstand? I lost my booklet. thank you
Here is the link:
Aug 08, 2010 | Odyssey Lstand Laptop Stand
How do i repair my B.C. Rich guitar??
Guitar manufacturers use generally one of two different knob types: (1) knob has a small set screw of some type holding it on or (2) press fit onto the shaft of the tuneing pot (volume knob in your case).
Now, the problem is if it is NOT a set screw type, it is press fit. You see press fit used most of the time on lower-end instruments (and a few high end). The BEST way to get a stuck volume know off is to get a shoe string, loop part of it under the knob, brace the guitar firmly and PULL SLOWLY WITH FORCE. Realize that it is possible to damage the guitar if you **** on the string too hard.
I have never seen where a stuck know did not come off (or hear of someone breaking their guitar doing it).
I have also resorted to using a small screwdriver: work it way under the know and gently twist it to loosen it so it can be pulled off with a string or your hands.
Be carefull not to scratch your guitar!
Good luck,
Mar 30, 2009 | B.C. Rich Nt Warlock Electric Guitar
Odyssey Lstand Laptop Stand Logo
615 people viewed this question
Top Odyssey Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an Odyssey Music Expert? Answer questions, earn points and help others
