Question about Philips 20PS40S 20" TV
3 of five local channels went to snow
We are rural and not cable. Running on antenna. Last night 3 of 5 local channel went to snow with programming in background. Not the cable which has been checked for damage. It also operates when a portable TV was plugged into it. TV is a Phillips 20PS47S301 from April 2003. Can get to the autolock portion of the remote because the factory access does not work (0711 pressed twice). Out of ideas and have tested everything in the manual. Thanks
Are there any lightnings or thunder in your area when it happened.try checking your tuning settings,maybe the program was reset so u need to reprogram the channels again.try removing the batteries of your remote and put it back on again then try to access.i have encountered that problem and i end up buying a new
tuner module.and that fixed the problem.
Posted on Jan 28, 2009
Cant get my digital antenna to pick up any channels
In your area, it may be necessary to use an antenna with an amplifier.
Jun 29, 2017 | Televison & Video
Cannot receive tv channels
if you are using a cable box tried to reset the box first let see if you can get channel. if you are just only using an areal antenna tried to make an adjustment in the antenna positioning which have poor reception then tried to look in other channel if you can receive local channel. if just only white raster like snow with no picture the cause could be the tuner get bad.
Nov 08, 2012 | Proview PA-32JK1A 32 in. LCD Television
How can I get just local channels only without a cable provider
A set of digital rabbit ears or small digital antenna will pull local digital stations out of the air waves for free. If you live in a rural area you will need one of the better digital antennas and not the portable ones.
Oct 18, 2012 | Televison & Video
Scheduled a timer recording of a program on a DVD+R and when I went to play it back all I got on the screen was noise and snow. I now realize that I used the wrong disc (should have used only DVD-R). ...
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Aug 10, 2011 | Toshiba DVD Recorder
Does emerson model #20s5b have a switch to convert from cable to satilite?
It's in the channel programming menu. It should say, "Cable/Ant" or "Cable/Air" If you want a roof antenna with local channels, change it to "Air/Ant" Then click auto program with the antenna hooked to it to scan for free local channels.
Jun 16, 2011 | Emerson Televison & Video
MY TV only goes to channel 3 and dvd mode and i dont have the remote that came with it can someone help me.
walmart, universal remotes from $7.00 and up, the problem should be that channels up to 3 were blocked and you need to re program channel search on menu, cable or antenna option and then, locate channels with signal, if you watch tv from cable, the channels search only detected the channel 3 as a channel with signal, if the tv is not hdefinition, you wont need more channels, if it is hd, there is an option for dvd, antena (hd signal of course) and hdm or whatever signals capability, I hope I helped you, othewise, contact me and I will be more than happy to help, God bless
Jan 26, 2011 | Philips 25PS40S 25" TV
I can't get all the antenna channels
I do not know if your in the USA or a international country or what have you. But part of the reason why older tv's still get a RF signal is because of there older tuner inside. Now I know the USA went digital last year and in saying that this could be you problem but lets not put the horse in frount of the wagon here. You might want a try a better antenna first to see if the inporves things. But most tv's use UHF/VHF/IRC/HRC and the older ones just use UHF/VHF and only can pick up channnels with those tech. But your newer ones block out low frequencies UHF/VHF is its harder to get a signal. I would say try a better antenna or you might bne in a digtial area where you need a little converter box.
please be considerate and rate with the thumbs to your top right before you close the window, alos if you will leave me some feedback.
Apr 13, 2010 | Samsung HP-S4253 Television
How do I set my PT-44LCX65 up to receive broadcast HDTV signals.
You should use the auto-program function in the customer menu. It will prompt you to select which antenna input you wish to program and then ask if you are on cable or receiving signals via "air" or "broadcast" mode. Allow the TV to load all the channels. You may notice that the auto program mode may move along quickly during the addition of analog channels and that during the scanning of the digital channels that it may look like nothing is happening. Patience is a virtue here. Wait until it has completely scanned both analog and digital bands and you will recieve both versions of the station's signal. If, for example, you have a local channel 5, the digital version will be 5-1, and so on.
Dec 18, 2008 | Panasonic PT-44LCX65 Television
Can't get any tv reception
My friend, you need to hook up a signal source such as an antenna or cable . The channels wont come in and it will all depend on where you live and how close to a major city on what and how good you will get the stattions. then once an antennena is connected, do the auto programming again. Good Luck
Aug 18, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Philips 20PS40S 20" TV Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
