Question about Brother Ml100 Standard Electronic Typewriter 16-2/5x15-1/8x5-1/3 Gray
How do I put the pinwheel back in - Brother Ml100 Standard Electronic Typewriter 16-2/5x15-1/8x5-1/3 Gray
  • Brother Master
  • 3,594 Answers
Remove the ribbon, pull the release lever (I believeit is black and and to the right of the P/W), drop theP/W in with the tab to the right, close the lever.
DickyO
Posted on Jan 25, 2013
New saw.2025,bought new and they put chain on backwards and will not cut.runs great but having problem loosening pinwheel chain adjustment.flip up lever but cannot loosen it.too tight
If you can't even loosen it to get the chain off and put it back on properly take it back to the people who put the chain on backwards. That is absolutely ridiculous that a dealer puts a chain on backwards...they probably just tightened it too much...use a bigger screwdriver as to not strip the screw. It should never be that tight...they may even have the wrong size chain on it, check the chain package too , make sure its the right one for your bar......Take it back, If they can't loosen it easier and in a reasonable amount of time or you see them forcing it, demand a new saw. Seriously.
Apr 26, 2017 | Garden
How to fix back the pinwheel
put the wheel in align the hole in it with the pin on the driver and snap it in
Feb 28, 2014 | Nakajima Office Equipment & Supplies
Need new 3 pitch pinwheel for Brother ML 300
I don't Believe that there is such a thing, there are 10/12 wheels.
DickyO
Mar 30, 2013 | Brother ML-100 Typewriter
What is the correct way to put the pinwheel in
Remove the ribbon, pull on the black lever right of the hammer, drop the P/W into the opening, push the lever back..
Go to NADIST.COM, click on current models you will find a manual there.
DickyO
Sep 07, 2011 | Nakajima AE-710 Typewriter
On Duet Front Loader- Error code F/H. Can see plenty of water coming in so I suspect pressure switch. Is this a common problem? I don't quite understand your pressure switch check procedure in your...
This error code F/H tells that no water entering the machine is detected during the fill step of the wash cycle. It can be due to siphoning, pressure switch not tripping or stuck in the empty position, or the water flow meter is not reading the correct water flow. Make sure that no water is draining out of the drain hose due to siphoning as water fills in and position the end of the hose to prevent such condition.
The pressure switch is stuck and not tripping if after 8 minutes the water flow meter has detected 10.5 gallons of water passing through it but the control has not detected the pressure switch trips. The water valves are then turned off and the error code is flashed. The error code is also flashed if after 30 seconds the water valves are turned on and no water is detected entering the machine due to sticking flow meter pinwheel or the flow meter is not positioned properly.
The flow meter is position sensitive. The pinwheel must be installed vertically. Any canter to it may cause the wheel to stick. Many times the F/H error code pops up only when HOT water passes through the flow meter. The hot water may be softening the hoses on either side of the meter, causing the flow meter to canter. Stuck or cantered pinwheel affects the flow meter's ability to read water flow accurately. Disconnect the hoses from the flow meter then blow air into the inlet to free a possible stuck pinwheel. Replace the flow meter if the pinwheel is totally stuck and cannot be freed.
Check the pressure hose for possible kinks or air leaks if the flow meter pinwheel is positioned vertically and turning freely. Kinks and air leaks in the pressure hose prevents pressure built up in the pressure switch dome and the pressure switch cannot trip. Check the pressure hose including its connections to the pressure switch and the bottom of the tub. Blow air into the pressure hose to clear possible clogs or kinks and check it for air leaks. Also blow air into the pressure switch dome to free a possible pressure switch contacts welded or stuck in the empty position. You should hear the pressure switch clicks if it is tripping. Replace the pressure switch if not tripping and the pressure hose has no kinks or air leaks.
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hf error message
The central control unit does not detect water entering the machine 30 seconds after the water valves are opened or the pressure switch did not trip 8 minutes after the flow meter detected 10.5 gallons of water passing through it. The problem is therefore either the flow meter, water inlet valves, or the pressure switch.
Check the level of water inside the tub when the error code flashes. The pressure has not tripped if there's enough water inside the tub. Verify the condition of the pressure switch hose and the pressure switch itself. Make sure the hose is not kinked or clogged. Disconnect the hose from the switch then blow air forcefully down the hose and then the switch. You should hear the switch click when blowing air into it. Replace the switch if the problem persists.
The problem is in the water inlet valves if there's no water at all that has entered the tub. Replace the valve assembly if that is the case. But if there's some water that has entered the tub, then the problem is in the flow meter. Check to make sure that the flow meter pinwheel is oriented in the vertical position. Remove the flow meter and blow air through it to free the pinwheel from possible stuck up. Replace the flow meter if the pinwheel is broken or frozen.
Dec 29, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have an Macbook Pro, and I get a spinning pinwheel of color that stops everything from time to time or I get my safari totally shutting down. What up?
That little pinwheel is the Mac "loading" wheel. Kind of like the hourglass in windows. I found a link on how to reduce the loading wheel in Safari at this website. http://reviews.cnet.com/8301-13727_7-10328447-263.html
Happy computing.
-CompDoctor
Feb 22, 2010 | Apple MacBook Pro Laptop Computer with...
Need new pinwheel, where can can I get one.
We have the printwheels New 39.95 a good used one 19.95.
DickyO
1-216-241-0027
Oct 21, 2009 | Brother SX-4000 Typewriter
IBM Wheelwriter 6 - cannot print
The print solenoid, just inside the L. printer side frame has a plastic cap on the plunger it is probably broken, they are available but a little tricky to install.
DickyO
Mar 15, 2009 | IBM Wheelwriter 30 Typewriter
Brother Ml100 Standard Electronic Typewriter 16-2/5x15-1/8x5-1/3 Gray Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
