Question about Frigidaire Dishwashers
Top rinse arm fell off into machine - Frigidaire Dishwashers
  • Frigidaire Master
  • 17,129 Answers
You might need to replace the arm
Click this link: Spraying arm
Posted on Jan 24, 2013
3 Suggested Answers
planet-x
  • 232 Answers
SOURCE: Upper rinse arm fell off. How does it reattach?
usually it will clip to the basket that holds cups and the like, and engages with the water outlet when the basket is slid into position. Some spray arms have a locking ring that, when the spray bar is held in place, rotates clockwise (if viewed from underneath) and locks the spraybar in place.
Posted on Nov 06, 2009
  • 3 Answers
SOURCE: the top water spinner arm fell off, how to get it
This just happened to me. The spinner arm fell off. It left behind two pieces of plastic attached to the roof of the machine: a grey sunburst shape, and within that, a white circle with two prongs. It looks like the spinner arm should snap onto the white circle with prongs . . . but you can't just press it back on, because there is no resistance on the other side and the white circle just becomes displaced instead of snapping together.
But the good news is that the grey sunburst screws on and off! Unscrew it until it comes free from the roof of your machine. Now snap the white circle and the spinner arm together, with the grey sunburst between them. Give it a test spin to make sure it's all together and working, and then screw the whole assembly back onto the roof of your dishwasher.
Apologies for the lack of pictures . . . this must sound crazy to anyone who's not looking at what I'm looking at--but it worked!
Posted on Nov 03, 2010
Machine Running noisy during cycle
lift off spray arm and remove motor rotor and remove any debri this can cause a noisey motor.
Sep 04, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
Machine runs but not cleaning dishes
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
My whirlpool washer stop working before it rinses
you need to check the lid switch,and the actuator arm
Mar 12, 2010 | Kenmore 22942 Top Load Washer
The top water spinner arm fell off, how to get it
Feb 25, 2010 | Frigidaire PLD2855RFC Dishwasher
My steam/hot water arm fell out along with no steam
Easiest way to get to it, remove the 2 screws in the bean hopper, and remove the hopper, there are a few screws under the water tank, this should give you access to the machine top. Check the end of the steam wand it might be blocked use a paper clip to clear it out. Run it under the faucet to make suree it is clear. Check the microswitch that is connected to the steam valve, It can be seen when you turn the knob to open the steam/hot water valve, make sure it is not stuck in the on position.
Dec 06, 2009 | Saeco Vienna Espresso Machine
Nov 06, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
No water pressure in rinse cycle
AM 14's need 20 PSI flow rate of rinse. Is your pressure gauge accurate? Could the rinse nozzles be blocked with scale? If you remove them to clean, make sure they go back in the same positions. Note the upper arm has one each side pointing up, to clean the top of the machine. Check that the upper rinse arm has it's thrust washer under it's hub.
May 05, 2009 | Hobart AM14-253 Free-standing Dishwasher
Arm on ice machine fell off. Where do I find
Hi Pat,
Here's a "home made" diagram I made. Hope this helps!
Please rate my solution. Thanks!
SG
Apr 19, 2009 | Kenmore Refrigerators
I have a hobart dishmachine model# CRS-103
THERE SHOULD BE SOME HOOKS AT THE TOP OF THE MACH INSIDE AT BOTH ENDS AND SOMEWHERE IN THE MIDDLE TO SEPERATE THE WASH TANKS AND THE RINSES TANKS, ALSO AT THE ENDS SO THE WATER DOESNT SHOOT OUT ONTO THE FLOOR,THE SPRAYERS COULD EITHER BE THE WASH ARMS OR THE RINSES JETS IF ITS THE ARMS THEY GO IN THE TOP AND THE BOTTOM ONES GO JUST ABOVE THE WATER LINE OR SCRAP TRYS THE BOTH SHOULD LOCK IN SOMEHOW,I IF ITS THE RINSE JETS THE GO IN THE RINSE ARMS WITCH ARE AT THE EXIT END WHERE THE TRAYS COME OUT, THE JETS SHOULD THREAD INTO THE ARMS WICH HAVE PRE DRILELED HOLES FOR THEM.
Dec 23, 2008 | Dishwashers
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
