Drum seems loose and bangs all the while it is spinning. can move it side to side and front to back easily by hand. where should i look for the problem?
  • Washing Mach... Master
  • 17,129 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Thank You for using fixya
Posted on Jan 24, 2013
docjohn174
  • 943 Answers
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
barkencoa
  • 3463 Answers
SOURCE: drum is loose and banging on hotpoint aquarius wf541
This sounds like a classic case of main drum bearing or drum support failure, it is a major repair and not really a DIY repair, unless you are coversant with w/m's
It involves a complete strip down and in some cases it is neccessery to to have to replace the drum as well.
The cost of the parts involved is well in excess of £100.00,and it really is not an economical repair.
I think you would be better off buying a new washer.
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
onthejob5130
  • 640 Answers
SOURCE: spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Posted on Feb 07, 2009
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
heatman101
  • 43501 Answers
SOURCE: Hard bang on spin with my frigidaire gallery frontload washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Apr 15, 2010
Testimonial: "Ok that was my guess. That answer was lightning fast. Thx you very much. Will remove it. test it and post if the problem is fix. Thx again"
My whirlpool top loader bangs around during final spin
Kindly provide few details :-
1. Make and model of the washer?
2.How old the washer is?
3. Is it banging only at high speed or even on slow speed?
4. Is it only during the final spin or all the time during spin?
5. If you move the drum by hand, is there any noise? Could you turn the drum easily?
Kindly answer all the questions.
Thanks!!
Sep 02, 2010 | Washing Machines
heatman101
Apr 15, 2010 | Frigidaire GLTF1040A Front Load Washer
Loose drum bangs during spin cycle turn by hand with nothing in drum and still bangs?
your front drum support blocks have failed. remove the tub and, replace or, rebolt them in place so they hold the drum front in place.
Jan 25, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Drum is banging on wash cycle.
Hi
I am not too familiar with KitchenAid products as we dont have them in Australia. However most front load washing machines have the same basic set up.
Open the top hatch and also the back panel. Check the suspension springs on top of the drum and also the shock absorbers underneath the drum.
Make sure they are ok and non has come off or broken during the move.
Also make sure that the counter balance bricks or blocks are not brocken or loose.
Good luck.
Ash
Oct 31, 2009 | KitchenAid KHWS01PMT Front Load Washer
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
The drum bangs on the spin
Two possibles for this are aloose balance block or cracked drum spider.The front block is most prone to coming loose.
To check spider rotate drum little by little and pull towards you to check for movement.
Post back if further help needed.
Thankyou
Dec 19, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Machine banging when in fast spin
or the three legged spider that attaches to the drum. its made of cheap metal and one or more legs can crack or break letting the drum loose - seems like bearing but isn't! cost about £40
Sep 28, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
