Question about Cuisinart Supreme Grind DBM-8 Electric Burr Grinder
Cuisinart DBM-8 Grinder Automatic Burr Mill stopped grinding
First intermittantly ground. then it stopped grinding. Started again after smacking it a few times, but now it stopped grinding again.
  • 1 more comment
  • kmbuono
    kmbuono May 15, 2012
    My grinder completely stopped. Remove the chamber that holds the grinds and clean out the opening where the grinds enter the chamber.
  • Anonymous Mar 22, 2014
    mill starts to grind and immediately stops.
  • Anonymous Mar 25, 2014
    stopped grinding
Perhaps remove the hopper (top) and inspect to see if a buildup of very fine compacted grounds as accumulated. knock the stuff loose.
Posted on Mar 28, 2009
We have one that is about 3 years old. First he timer part stopped working so you'd have to hold the button down to grind, and then the whole thing just quit. I opened it up (screws under the rubber feet) and found two problems on the circuit board: first, there was a capacitor which had
broken a leg, which I re-soldered back on. Second, I resoldered the timer chip as it looked like it had some bad joints.
I am guessing a lot of these units seffer from simmilar problems due to the intense vibrations the thing has to withstand.
Posted on Feb 28, 2010
How do i clean dbm-8 grinder
Do yourself a favor and got the right kind of grinder for the coffee you drink. If you have a dry coffee use a grinder. High oils in some coffee need the blade type of grinder. Usually you can tell by looking inside the bad. See oily coating get a blade type.
Feb 19, 2015 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart DBM-8 coffee grinder started by itself.
Mine did it as well. I had an electrician out to check out the outlet. He replaced the outlet, but it still has done it. It freaks me out, so I unplug it after use.
Nov 02, 2012 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder will not grind or turn on
will not stay turned on. have to keep hitting start button
Jun 28, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder does not run at all.
MY DBM-8 CRUISINART WILL NOT GRIND COFFEE BEANS THE
Apr 04, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder will not start
Make sure that the coffee ground container is fully inserted. You may need to make sure there are no grounds are keeping it from seating properly. Use something soft such as a toothpick to clean it thoroughly...Good Luck.
Mar 05, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
My Cuisinart CCM-16PC suddenly decided not to burr/grind coffee. It doesn't turn on. Electrical recepticle is hot and the device is plugged in. I've cleaned all of the connections/buttons/grooves so...
Same thing happened to me about 1 year ago. I took the machine apart and determined the issue to be in the circuit board. I bypassed the board and wired the power cord directly to the motor. The machine began to work and is still operating fine. The only drawback, of course - having bypassed the circuit board and switch, you now are on full manual operation. Plug the power cord into the wall outlet and the motor spins; when you are finished grinding you have to remove the cord from the power source to stop the motor. I am OK with this - beats 35 - 50 dollars for a new grinder. Dave
Feb 28, 2011 | Cuisinart CCM-16PC Supreme Grind Automatic...
When grinding coffee beans the grinder is not dropping the beans into the grinder part. I have to stay and shake or bang the grinder on counter to get the beans to fall through.
you must screw off the burr holder plate screw (in center) you will order one special screw, drill shaped, when the burrs roll it will mix and take down the coffee beans. That is solution i applied to many grinders. PS: beware the direction of burrs must be coordinated with new screw.
Feb 07, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder fell. Black "button" inside broke off.
Use just about any 2-part epoxy, clean parts with rubbing alcohol first to remove coffee oil and get a good bond.
Nov 08, 2010 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart DBM-8 Supreme Grind Automatic Burr Mill stopped grindin
We are on our second and last machine; after this DBM 8 goes out, I am going to find the most basic grinder I can and stick with it. That said, I fixed ours by removing the clear plastic reservoir where the ground coffee ends up, and then removing the build-up of coffee grounds around the exit chute where the ground beans enter the reservoir.
So, slide the reservoir out, just as you would when emptying it in to your coffee maker and set it aside. Have a flashlight ready when you tilt the grinder forward. On the back side you will see the hole where the ground beans empty into the reservoir. Take a toothpick and get rid of all the clay-like coffee reside that has built-up around that hole. Use a can of dusting air, if possible, (the aerosol "can" type used to blow dust particles from your computer) and blow away all possible ground coffee residue in the hole and around it. This will allow the reservoir to seat snug and flush again. This process fixed ours and I don't know why for sure, other than I suspect, the clay like build-up of coffee grounds, over time prevents the reservoir from seating properly and it has to seat perfectly to work. Good luck.
Jan 28, 2009 | Cuisinart Supreme Grind DBM-8 Electric...
Dead machine
It's under warranty, contact Cuisinart for repair.
Jun 21, 2008 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart Supreme Grind DBM-8 Electric Burr Grinder Logo
2,103 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
