Question about DeLonghi TRN1015T Solaris Oil-Filled Heater Oil Filled Radiator
Delonghi Solaris Heater Model No. TRN0812T NOT WORKING
Our heater was working well till day before yeaterday.Before going out that evening we switched off the switch but the plug was plugged in.When we returned and press the switched on...we saw its not working.I dont know where is the fuse of this heater because outside of the heater they has written not to open.How will i see whether the fuse is ok and what maybe the problem? I have the same problem! The first three times, the heater worked perfectly. I've been following the manual to a T. And when I got home today and turned it on, nothing! I am soooo frustrated ...
TRN0812T does not turn on anymore
Put your hear at the thermostat. Move the dial with length. Can you hear an it click on and off?
Try another outlet. Is the outlet working?
Tilt it to the floor and back (safety to shut off if tilted).
There is not much to a heater. Element on/off switches. Thermostat. Tip over safety switch.
Noting meant to be repaired. Give it a good smack before throwing it away.
:o)
Jun 03, 2011 | DeLonghi TRN0812T Radiator Heater
It stopped working
If its like the TRN0812T, I had to reset the small circuit breaker under the control panel/cover, had to remove the 2 torx screws under the leg on the control panel side.
Feb 02, 2011 | DeLonghi TRN1015T Solaris Oil-Filled...
Was working yesterday, now it won't turn on
http://www.fixya.com/support/t8108827-stopped_working
Jan 31, 2011 | DeLonghi TRN1015T Solaris Oil-Filled...
Delonghi manual
http://www.delonghiusa.com/downloadpdf.php?nid=33
Nov 17, 2010 | DeLonghi TRN0812T Radiator Heater
I inherited this heater with no manual and am in need of some instructions on how to properly use it and how to set temperature etc.
Go to Delonghi web site http://www.delonghi.com/ select country you are in. Select Customer servivices and then Down load instruction manuals. Hope this helps.
Aug 09, 2010 | DeLonghi TRN1015T Solaris Oil-Filled...
Will not turn on
Not a solution, but there seems to be a lot of this going around: ours (seldom used) just stopped working, one month past the 1-year warranty period. Arrrgghhh....
Dec 06, 2009 | DeLonghi TRN0812T Radiator Heater
In the past I have nothing but problems with DeLonghi heaters. I replaced them with Pelonis heaters and have had no problems since. Pelonis heaters are availible from Home Depot at a very reasonable price. This is based on my experience only. Hope it helps.
Ray
Dec 08, 2008 | DeLonghi TRN1015T Solaris Oil-Filled...
Delonghi TRN1015T wiring diagram
Just wondered how you learned to turn off the timer.
Jan 10, 2008 | DeLonghi TRN1015T Solaris Oil-Filled...
DeLonghi TRN1015T Solaris Oil-Filled Heater Oil Filled Radiator Logo
287 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
