Question about Compaq Presario CQ60-220US PC Laptop
Screen shows 'system cannot find the path specified, 0x80070003.
Will not boot up or start windows
  • Compaq Master
  • 27,725 Answers
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty. Although it would be very rare for the sata lead to be faulty. Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Jan 24, 2013
Microsoft Windows could not start the windows installer service on local computer error 3: the system cannot find the path specified
What is the Operating Software? If It XP SP1 or 2 you have install windows installer version 3
Sep 04, 2014 | Computers & Internet
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
May 15, 2014 | Microsoft Windows 8 For Tablets
Gateway laptop ml6732 has a startup repair screen and won't boot
Please re install OS .
Please specify what exactly went wrong when u used setup cd to re install
Jan 05, 2013 | Gateway ML6732 Notebook
Toshiba sattelite A205 s5816 will not boot up
i suggest getting/borrowing usb cd/dvd drive and then reinstalling your OS
Mar 09, 2012 | Computers & Internet
I cannot get my computer to boot. It just goes to a black screen after the acer logo and then the Microsoft loading screen comes up and then goes back to the black screen and that's it. I tried system...
This is a hard drive issue, remove hardware and reseat it back into place, sometimes this will work and run fine. But it is more than likely your hard drive will need to be replaced.
Mar 06, 2012 | Acer Computers & Internet
The Windows Search service stopped working on my Win 7 machine. Said indexing was not turned on. I used event viewer and found the following error message: The Windows Search Service has failed to...
1) Insert your flash drive
2) From the Start Button, type "services.msc" in the "Search programs and files" box
If prompted for Admin Access, answer yes
3) Scroll down to the "Windows Search" service, select it, and click Stop.
4) From the Start Button, type "regedit"
5) Browse to [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Search]
6) Verify that the values DataDirectory and DefaultDataDirectory are set to %ProgramData%\Microsoft\Search\Data\
7) Remove the flash drive
8) Reboot (or restart the Windows Search service)
Jul 26, 2011 | Microsoft Computers & Internet
Need to run HP PC System Recovery on Pavillion a775c. Files corrupted - fixing this older computer for a friend. No virus protection. Only one user account (the administrator). Cannot start any program...
One way but its drastic, you could replace the Hard Drive. It makes me think that it might be the hard drive because windows cannot boot from the drive. Its pretty easy to replace a hard drive, then run the system recovery disc.
Jun 07, 2011 | HP Pavilion a775c (A775CB) PC Desktop
1) user profile service failed the logon. 2) I cnt create new user acct of administrator type from othr acct w/c is a standard acct. 3) I cnt log on to my administrator user acct.
Hi jeff_lat23,
Welcome to FixYa! How are you doing?
You did not specify what operating system you are using, whether Windows Vista or Windows 7. When did the problem start? Did it happen just recently?
Please try to do the following to resolve the problem:
1. Please try to boot your computer to safe mode. You can boot to safe mode by doing the following:
  • Turn off the computer. Turn on the computer then immediately start tapping the F8 key repeatedly.
Note:
You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu does not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
  • Use the (Down Arrow) arrow key on the keyboard, scroll down to Safe Mode then press Enter.
  • Login to your User Name.
2. Use System Restore to restore the computer's settings to an earlier date:
  • Navigate to the Start -> All Programs -> Accessories -> System Tools.
  • Click on the System Restore program icon.
  • Click Next > on the Restore system files and settings window.
  • Choose the restore point that you want to use.
Note: Check the Show more restore points checkbox to see more than the most recent restore points.
  • Click Next >.
  • Click Finish on the Confirm your restore point window to begin the System Restore.
Note: Windows will shut down to complete the System Restore.
Hope that helps
. Thank you for using FixYa!
Apr 21, 2011 | Computers & Internet
Start menu and icons are not showing up on screen
Ann, At boot up press F8 and boot in safe mode. Once windows shows up, Start->All Programs->Accessories->System Tools->Restore. Here you must specify a date that is in bold numerals. It will reboot in a short while. And you will get a working computer.
Oct 07, 2009 | Dell Computers & Internet
Compaq Presario CQ60-220US PC Laptop Logo
19 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
