Question about Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW how to replace paper feeding roller?
There is a grinding noise when starting the printer
  • 826 Answers
From here download the pdf to learn how to replace paper feeding roller...
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Jan 24, 2013
Mix-it-up
  • 832 Answers
SOURCE: brother mfc 5460 cn Paper jam problem
thx infonet. Sorry for reading that you have another prob. Did you open the printer? In case yes, you might have disconnected the small plastic foil which leads the printhead (encoder strip). The foil is located paralell to the driving belt of the printhead. try to fix it in place again. Have a look at the foil (encoder strip): is it stained with ink? If yes you need a new encoder strip. If not you have to place the head on the leftside (where the three white disks are) You can pull the head up in that position and watch the encoder strip when pushing it back in place. Another reason could be that the head crashes somewhere on his cycling way: Open cover and press the two plastics by thumb (located on the other side of the arrow-knob facing to inside) to avoid : cover open message. Power up machine. watch the head cycling. Does it run the hole way from right to left side and back? Or does it stuck some where? Please write here where it stopps.
Posted on Sep 16, 2007
  • 526 Answers
SOURCE: brother mfc-7420 printer - manual feed instead of automatic
ok, thank you
you probably had a document that was not using 8.5 x 11 paper or the print settings were the printer to use the manual tray.
thanks adi
Posted on Apr 20, 2009
SOURCE: black dots on print outs from Brother Laser Printer MFC-9840CDW
meaning your printer drum is growing weak and will soon need to replace
Posted on May 23, 2009
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
  • 13 Answers
SOURCE: FEEDING PROBLEMS FROM PAPER TRAY
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist PhillyCopiers.com 215 364 3774
Posted on Apr 15, 2010
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Jul 01, 2014 | Brother MFC-9840CDW Laser Printer
How do I replace PF kit1 Brother MFC-8460n
The paper feed kit is the pick up rollers and the transfer rollers. You can thake those out clean them and replace them, but unless you are actually having paper feed issues usually just clean the paper tray feed rollers with alcohol and reset the paper feed kit counter if needed.
May 21, 2014 | Brother MFC-8460N All-In-One Printer
MFC 9450CDN is giving false paper jam message
try cleaning the paper feed rollers. false jam message can result from paper feed issues.
Apr 09, 2014 | Brother MFC-9840CDW Laser Printer
Suddenly, our Brother MFC 9840cdw keeps spinning its top paper feed rollers, forevier, and says Fax Only, Please Wait. When we press the Copy or Print buttons to get out of Fax mode, nothing happens. I...
It does sound like a paper sensor in the automatic document feeder may be stuck and the machine keeps trying to eject the paper that is not there. I have not seen this before, you may have to call Brother at 1-877-BROTHER to find the nearest service center.
Jun 02, 2011 | Brother MFC-9840CDW Laser Printer
Brother MFC 9840CDW When printing using paper from the paper tray, the printer will pull the paper up off the stack of paper from the paper tray but drops it at that point and will not feed it in to the...
Pull the paper out and look at the leading edge. If there is an indent in it then it is hitting an obstruction. remove the cassette and see if you can see anything it may be hitting. If there is no indent then the rollers are not gripping. You should not use alcohol on any rollers. Just use soapy water. Fairy liquid is great for cleaning rollers.
Apr 28, 2011 | Brother MFC-9840CDW Laser Printer
My Brother MFC-9840CDW keeps jamming every time I print mailing labels. I've had it four 1.5 years with no trouble. The label gets stuck and I have to pull out the toner tray to fetch it. I also...
hello, sounds like there are many possible solutions for you machine, first with paper jamming, are labels going thru manual feed tray, or paper tray, it might be possible that mp feed roller needs cleaning or replacing. if paper tray, simple would be feed roller, clean or replace, if jams continue with normal paper from paper tray, the problem will be front door, i have yet to be able to repair paper jams when front door assembly fails. as far as colors, both drum and toner can cause this problem, if using 3rd party toner, this will also cause some color problems. sorry no real quick fix for this machine, i've tried.
Sep 24, 2010 | Brother MFC-9840CDW Laser Printer
MFC-9840CDW Laser Printer: I have a Brother MFC-9840CDW laser printer it is o...
Wipe the paper feed rollers with a clean rag wetted with plain water. You can also replace the feed rollers, search for "paper feeding kit" for this printer. Should be $20 to $30.
May 18, 2010 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW puts black lines on edge of paper
Does this printer have transfer and pickup rollers? If so many times these rollers go bad and can cause that problem. If it uses powdered toner, check for toner buildup near the ends of these rollers as well.
Aug 10, 2009 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW Laser Printer Logo
246 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
